03-27-2012, 02:52 PM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
| dropped the Bully, joined the crowd build
Xr10 kit rc4wd bearings/sideplate rc4wd hardened gears Delrin topper 2 fxr's wantasummit dig dna aluminum front wheels (Berg offset) stock rear wheels replaced the upper 5x8 bearing with a bushing delrin over stainless rear bent links with revo ends gcm bent front links with stock ends The original topper prototype with borrow chassis (this was actually before I had decided to get an xr10) Original assembly with stock links fairly clean electronics package everything is nice and low as compared to my bully. As you can see, they are the same width... from the original practice session I need to get some pics with the bent links |
03-27-2012, 04:38 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
| Re: dropped the Bully, joined the crowd build
Looks really good!!! May want to flip the servo in the front and up grade to a beefier steering link, i've seen that turnbuckle set up snap on more than on rig. Im running a Jato and a Revo rod end screwed together, seems to be the right length and is really strong.
03-27-2012, 04:53 PM | #3 |
yup, servo link is on my list... I ran out of rod ends though.
03-27-2012, 08:51 PM | #4 |
I can cut a length for you and attach the rod ends if you would like. I'll bring it to the comp on Sat.
03-28-2012, 07:15 AM | #5 |
Im good. Ill be ordering a few packs soon enough. I want to redo the upper links. Sent from my DROID RAZR using Tapatalk |
06-12-2012, 06:43 PM | #6 |
I made some changes... some for the better some not. I flipped the servo, made a new linkage, trimmed the servo guard a little so it doesnt rub the tire and swapped in some aluminum c's (already had aluminum knuckles). I also swapped the shocks for Traxxas bigbores with Jeepindoug balls on top and out boarded the rears. Unfortunatly, now the suspension is way to tight so I need to find some different springs. (I installed some Losi grey, golds were too soft) I still wasnt happy with how the truck performed Saturday (second win in a row) so, I made a couple adjustments. -rear shock position changed to give more ground clearance. -rear wheels changed over to aluminum to stop beads from pulling and add a little low weight -steering linkages replaced with solid rod (Thanks Dave) I got a little happy with the sander and went too deep on the axle case so I used some black styrene and some ca. |
06-13-2012, 02:01 PM | #7 |
Looks good... How do you like how it drives vs. the Bully? I ask since I ran a 2.2 Bully for ~1 year (still have it) but bought a used XR-10 this spring. It's still fairly stock (replaced front uppers with Axial machined, replaced rear uppers with my own aluminum tube type), I also modded the C-hubs to allow a little more clocking and did the axle bearing shim trick. For me, what may have been work with the Bully seems easy with the '10. On the other hand I have to remind myself, "It's an XR-10, don't jump the throttle when bound up.....it's NOT a Bully!!" |
06-13-2012, 02:30 PM | #8 |
Rock Stacker Join Date: Jun 2009 Location: Denmark
Love your cab are the templates for sale?? |
06-13-2012, 06:26 PM | #9 |
| Re: dropped the Bully, joined the crowd build Its a world better than the bully. I was first to preorder the bully axles and first to get them. They are nearly indistructable and I was able to dominate the local series for a couple years with them... Over the past year I started loosing comps because we were making the courses harder and harder and the bully couldnt keep up. The xr10 axles are definatly more fragile though. Even with larger bearings and hardened gears, I got some skipping at the last comp. I have gotten tons and tons of request for them. We have a great club member with a cnc router who has been cutting them for locals but, at this point I dont see myself getting back into vending. |
06-14-2012, 06:13 PM | #10 | |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
| Re: dropped the Bully, joined the crowd build Quote:
06-28-2012, 03:23 PM | #11 |
someone mentioned carbon fiber so I picked up a sheet of 1/16 rigid. |
08-16-2012, 04:00 PM | #12 |
While I was swapping on some new shoes I decided to lighten things up a bit... Total loss is 1/2oz. I know its not much but its something. |
08-16-2012, 04:20 PM | #13 |
| Re: dropped the Bully, joined the crowd build Im down to 5# 15oz. Still heavier than I want but, the weight is at least where I want it, low and forward. |
08-16-2012, 07:21 PM | #14 |
Quarry Creeper Join Date: Nov 2011 Location: PDX
That thing looks awesome!!!!
dropped the Bully, joined the crowd build - Similar Threads | ||||
just joined | littleyj | New Hampshire | 6 | 04-04-2010 06:53 AM |
Joined the Club | LeDevil | HPI Wheely King | 19 | 03-08-2010 09:38 PM |
well..joined the fj cruiser bandwagon | chino438 | 1.9 Scale Rigs | 10 | 05-09-2007 06:15 AM |
