Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Average upgrades?
Old 04-16-2012, 10:28 PM   #1
Default Average upgrades?
I know its a weird question. But If I take a stock xr10 and put rc4wd gear sets, Vanquish Gear cases and motor plates of whatever brand? With 45t motors running 3s and maybe some link upgrades?? How durable would this setup be?? electronics I will upgrade with $ etc.. Thanks for the help guys! Im assuming that the stock gears wont last very long? From what ive been reading?
gtxr is offline   Reply With Quote
Old 04-16-2012, 10:59 PM   #2
Default Re: Average upgrades?
do the traxxas bushings an you will be money with the other stuff you said
slowride1 is offline   Reply With Quote
Old 04-17-2012, 07:14 AM   #3
I drilled the plates and upgraded to 9mm bearings, bushings in the cases and link mounts with RC4WD gears. Running 35t HH on 3s no issues.
DioptricStraw is offline   Reply With Quote
Old 04-17-2012, 03:09 PM   #4
Sorry for the newb question? But what do you mean buy traxxas bushings? Thanks
Old 04-17-2012, 03:53 PM   #5
Replacing the tiny 5x8mm bearing on the top shaft with an oilite bushing that won't disintegrate and destroy the gears.
AreCee is offline   Reply With Quote
Old 04-17-2012, 04:23 PM   #6
get rid of the little bearing in the upper link mount trust me iv blown that out so many times get the bushing
asw27x is offline   Reply With Quote
Old 04-17-2012, 07:57 PM   #7
Part # TRX3775
Rob450FE is offline   Reply With Quote
Old 04-17-2012, 08:10 PM   #8
I would suggest the VP bronze bushings and RC4WD gears. If you use the VP bushings you wount have to drill or replace the motor plates. A lot of people have good luck with the Traxxas cast bushings, but I have split and broken so many its VP for me, and if you use the Traxxas bushings you will still need to do the 9mm bearing mod or replace the motor plates.. That will get you where you need to be untill you can do more later.
KBrog is offline   Reply With Quote
Old 04-17-2012, 08:40 PM   #9
If you have some mechanical ability, then do the 9mm bearing mod in the stock motor plates, the traxxas bushings everywhere else in the gear cases, the "mark reel" 2 extra bolt mod in the rear housing, you'll have a pretty durable setup. Stock gears and all. You may still break the 12 tooth gear shaft if you have no throttle control (full throttle when bound up).
If you'd rather just throw money at it, get VP or RC4wd motor plates, either the RC4wd or Axial machined gears, and the traxxas bushings.
IMO, there's no need for the aluminum gear cases at all. 100% pure bling.
Manning is offline   Reply With Quote
Old 04-17-2012, 10:40 PM   #10
Great stuff guys thanks for all the help!! Sounds like the bushing are the way to go for $ sake!! WIll definately look into it etc! Appreciate all the help!
Old 04-17-2012, 11:00 PM   #11
Can anyone give me a part # for Decent 9mm bearings?? Oh and what size drill bit you all using?? Thanks again!!
Old 04-18-2012, 05:02 AM   #12
Avid rc for the bearings, for the drill bit i went to a local hardware store (brafasco up here).
5x9x3 Flanged Rubber Bearing MF95-2RS
Old 04-18-2012, 05:10 PM   #13
I just bought the same ones for my xr. 9mm bit btw
Krawler23 is offline   Reply With Quote
Old 04-18-2012, 10:10 PM   #14
Hey guys! another dumb question!! Will the Spectrum DX3C work well with this rig?? Its gonna have an M2 dig with external bec!! Iknow iknow get better esc.. This is it for now!! Im wondering for sure? If the dx3c can be setup for front/rear dig and propo dig?? Thanks for the help!!
Average upgrades? - Similar Threads
not your average 1.9s kaneohecrawler Tires and Wheels 61 09-18-2011 07:39 PM
NOT YOUR AVERAGE 1.9s tAkE 2 kaneohecrawler Tires and Wheels 6 07-20-2011 10:10 AM
not your average nylint Bronco General Crawlers 12 04-05-2007 03:33 PM
