Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Tools for XR10
Old 04-21-2012, 05:55 AM   #1
Default Tools for XR10
My Xr10 should be here today. While it is already built with just about every aftermarket part that I could find; I know I will need to do some adjusting/fixing/maintenance from time to time. Is there a common size hex that most screws take? I know a good set can get pretty expensive so I will probably only buy a few really good hardened hex driver and a decent nut driver and then use my other tools for the rest. At least until my wife settles down from unannounced XR10 purchase
irokcrawl is offline   Reply With Quote
Old 04-21-2012, 06:06 AM   #2
Default Re: Tools for XR10
A 2mm (5/64" same thing as 2mm) is the most common hex size. 1.5mm for pinions. 7mm socket for the wheel nuts (get a good thin wall driver because some wheels have very little clearence). 5.5mm socket or open end wrench for those little nuts.
AreCee is offline   Reply With Quote
Tools for XR10 - Similar Threads
Tools Culetto Chit Chat 9 12-01-2011 10:40 PM
Where to get tools? BAXTER Newbie General 8 06-24-2011 11:43 PM
what tools are needed to put the xr10 together? minnesotamudder Axial XR10 2 09-04-2010 05:42 AM
Tools? suzuki_yota Newbie General 6 08-05-2008 04:13 PM
need help with how to use tools!! romeo26 Tools, and Procedures 13 06-04-2008 12:50 AM
