04-27-2012, 10:47 PM | #1 |
Pebble Pounder Join Date: Jul 2011 Location: Belgium
| XR10 stock schocks
Hey guys, Just finished assembling my XR, but i think the suspension is too stiff,i used the machined shock pistons with the 30wt oil,will it improve if i change the piston to the plastic ones with the largest holes? Thanks |
04-28-2012, 06:15 AM | #2 | |
| Re: XR10 stock schocks Quote:
The delrin piston (machined) works great with 30wt once you change the springs. Going to larger hole pistons will decrease the damping of the shock which will translate to more wheel bounce especially if you add weight to the wheel. | |
04-28-2012, 07:14 AM | #3 |
RCC Addict Join Date: Jun 2009 Location: Australia
Losi golds work well, but what works for one may not for another. But when I was looking I looked at as many build threads similar to mine to, learn what worked with other builds. Sent from my GT-I9100T using Tapatalk 2 Last edited by Oz Bruiser; 04-28-2012 at 08:01 AM. |
04-28-2012, 07:17 AM | #4 |
I've been reading trough every xr thread,but there is just to much info!!!!!!My brain can't handle it all!!!LOL
04-28-2012, 07:31 AM | #5 |
Rock Crawler Join Date: Jul 2007 Location: central PA
losi golds wakens the stock chassis up |
04-28-2012, 07:53 AM | #6 |
Anybody have a number for the springs? Thanks |
04-28-2012, 09:29 AM | #7 |
Rock Crawler Join Date: Oct 2011 Location: smithville
Losa5144 for the losi golds. I just bought these for my xr and wow! They make a huge difference, my sidehilling got a lot better and the shocks were much softer which let me get some more articulation which i needed. They also don't want to flip your rig over when going up with just one wheel on something, like the stock springs do. One of the best 10$ I spent on my rig for sure!
04-28-2012, 07:09 PM | #8 |
Rock Stacker Join Date: Jan 2012 Location: On the ledge. Look up.
I ran the Losi golds and they did well. I switched to Axial's 1.04 lb/in springs (black) on all four corners and have stuck with them since they came out. I like the latter better, but I run my crawler really slowly through stuff that puts a constant and rough bind on everything. Any heavier springs, even the 1.4 lb/in Losi golds, were not conducive to my grandpa style of crawling. For what it's worth, make sure your shocks aren't too full. ScorpionKing mentioned that to me a while back. Didn't realize I had been running them a bit too full since the XR came out. Got Axial's aluminum shock caps and the bleed holes on the side of the caps helps bleed out any excess fluid if you screw the caps on slowly. Or at least that works for me. Gonna go find my dentures. |
05-01-2012, 06:36 PM | #9 |
Just ordered my Sidewinder micros,and was wondering how to hook them up? I am also using the Novak dig. Any help is appreciated!!!!!!!!!! Thanks |
05-02-2012, 11:13 AM | #10 |
Nobody? Or any pointers in the right direction???? |
05-02-2012, 11:48 AM | #11 |
Newbie Join Date: Apr 2012 Location: Clear Lake, Texas
Try the electronics section and not a thread about shocks and you might get some help. I've never run those esc's so I'm no help.
05-02-2012, 11:55 AM | #12 |
Pebble Pounder Join Date: Mar 2012 Location: Visalia
| Re: XR10 stock schocks |
05-02-2012, 12:17 PM | #13 |
SVT Adam:i started this thread,just wanted to keep everything a bit together. But thanks for the tip,i didn't think about the electronics section!! |
05-02-2012, 12:36 PM | #14 |
Sorry I just realized its your thread Harley's thread has a wiring diagram in it too.
XR10 stock schocks - Similar Threads | ||||
schocks | BigKRI | Newbie General | 1 | 01-16-2008 03:39 PM |
