05-07-2012, 11:09 PM | #1 |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
| Aluminum hardware.
I am trying to figure out what aluminum hardware to order to replace all the hardware on the front and rear axles with aluminum. I took my list from the XR manual. It calls for alot of the self tapping screws meant for plastic. I am not having any luck sourcing those from fastner express or any other online vendor in fact. Are you guys just replacing them with regular M3 screws of the same length? Part of my difficulty is not having the XR axles in hand yet. The axles and chassis along with most of my build is in the mail. I have been running a bully for over a year and finally decided to switch over to the XR. Any help would be apprecieated. If the guys who have already done this have a list of hardware and quantity to order that would be awesome. Thanks. Ted |
05-07-2012, 11:27 PM | #2 |
Quarry Creeper Join Date: May 2007 Location: home
| Re: Aluminum hardware.
I just ordered up all the hardware to do everything on my XR...Everywhere I felt aluminum would be weak I went Ti. Since they all came in packs of 50 it was about $150+.... Id try sourcing somewhere that might sell individuals if your looking to save a buck. I got the standard M3...The fine threads should be stronger than a plastic tap thread... |
05-07-2012, 11:39 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
Hey Ted, Just look at your axles and for the front since you have the vp axle housing I'm pretty sure that the only self tapping screws you will need are for the chubs on the bottom. |
05-07-2012, 11:48 PM | #4 |
I haven't got the axles yet, but that makes good sense. I was just thinking that the tapping screws might be worth it to keep everything tighter.
05-08-2012, 12:28 AM | #5 |
Pebble Pounder Join Date: Jul 2008 Location: ov, sacramento
so, do you have the vp toppers or not? if you do. follow knoja's post.. if not, yes. the plastic stuff needs the tapping screws. you need the deep thread depth when your going in plastic. and even then it kinda sucks. machine screws in plastic wont last long. or you can do what i did and replace everything with the brass inserts. that would make everything in and out in your plastic housing adapt to machine thread 3mm. just a fyi though, i had about 5-7 of the inserts pop out over time (out of the 24ish total?) its still far better than the straight plastic imo. dap of ca on each side of the insert, press it in and thread a screw in it atleast 5 turns. and let it sit for a bit. they are actually pretty damn strong when you think about the stress your putting on it and clamping something to it
05-08-2012, 04:00 AM | #6 |
Pebble Pounder Join Date: Jan 2012 Location: On the rocks
You can buy plastic axles with the brass incerts from CKRC. I just put mine on and they work great. They come with the machine screws you need.
05-08-2012, 04:38 AM | #7 |
Rock Crawler Join Date: Jan 2011 Location: New Brunswick
Don't forget that most counter sunk screws can be traded out for button heads. That'll probably save you some $$$ at the checkout if you just go for one style of screw.
05-08-2012, 08:07 AM | #8 | |
| Re: Aluminum hardware. Quote:
As for brass inserts I would rather not, trying to keep weight down. I would like to find self tapping aluminum screws, but I can't seem to find them. | |
05-08-2012, 08:12 AM | #9 |
Just use a machine thread Al screw in place of the self tapping screw. They hold just fine.
05-08-2012, 08:24 AM | #10 |
| Re: Aluminum hardware. |
05-08-2012, 08:40 AM | #11 |
hey Ted, Those brass inserts don't weigh that much. you would only need 4 maybe 5 inserts to do a whole case. plus it gives you that added security. I can get a weight for you when i take lunch today. If you want, i have a shit ton of them still. |
05-08-2012, 08:50 AM | #12 | |
Where are you guys ordering your aluminum balls for rod ends? I will be using revo ends im sure. Last edited by TedBull; 05-08-2012 at 09:05 AM. | |
05-08-2012, 09:12 AM | #13 | |
Quarry Creeper Join Date: Nov 2011 Location: Thunder Bay, Ontario
05-08-2012, 10:53 AM | #14 |
I'm not a big fan of aluminum hardware seeing how they snap so easily in TC. If I'm going to stress things I want good old fashioned high strength steel hardware. The weight difference isn't worth a DNF and a difficult on site repair. Seriously, you have a rig that is between 5 to 8 pounds and trying to save what, 20 grams (2/3oz) at the most. However, colored aluminum screws sure does look nice. |
05-08-2012, 11:18 AM | #15 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
05-08-2012, 11:21 AM | #16 | |
Newbie Join Date: Jun 2011 Location: Pacific Northwest
Traxxas Revo Hollow ball set, aluminum Revo (30)/ tall centered hollow ball (2)/ tall offset hol [TRA5355X] | RC Cars & Trucks - A Main Hobbies Last edited by Infectious rc; 05-08-2012 at 11:28 AM. | |
05-08-2012, 11:32 AM | #17 | |||
Quote: | |||
05-08-2012, 12:29 PM | #18 |
So the rear case by itself (no screws or other hardware) is 1.40oz. With brass inserts it's 1.44+/-. So your looking at saving .05oz. The pro's out weigh the con's for me on this. I ha e as yet popped a rear gear since doing this mod. |
05-08-2012, 12:34 PM | #19 | |
05-08-2012, 12:36 PM | #20 |
Aluminum hardware. - Similar Threads | ||||
Aluminum Hardware interest? | Chris_The_Battery_Man | General Crawlers | 19 | 04-23-2012 02:41 PM |
Aluminum Hardware Metric | fa1rch1ld | Tools and supplies | 2 | 08-06-2011 07:17 PM |
Aluminum hardware | Beerman Crawler | General Crawlers | 2 | 04-08-2011 04:20 PM |
