05-26-2012, 09:28 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: On the ledge. Look up.
| Width at front upper shock mount stock chassis. Okay to go 45mm instead of 35mm?
Hey, Figured it's still early enough that I might be able to catch some folks awake and on here. On the front upper shock mount of the XR stock chassis...stock width up there uses a 35 mm wide piece of alum tube, rear is 45 mm tube. I've left the widths alone since I put it together back when it first came out, but was curious if anyone knows if it would screw up the triangulation angles if I bumped the front to a 45 mm tube to match the distance between upper rear shock mounts. Doing so would move the top of the shocks outside the angle of the lowers a bit and I'm uncertain if that would create an issue. Thanks. |
05-26-2012, 09:34 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
| Re: Width at front upper shock mount stock chassis. Okay to go 45mm instead of 35mm?
Did that to mine from day 1. If you use the stock body mount there are some spacers you can use but they just need top be trimmed a little |
05-26-2012, 09:57 PM | #3 |
| Re: Width at front upper shock mount stock chassis. Okay to go 45mm instead of 35mm? |
05-26-2012, 11:45 PM | #4 | |
| Re: Width at front upper shock mount stock chassis. Okay to go 45mm instead of 35mm? Quote:
Thanks. | |
Width at front upper shock mount stock chassis. Okay to go 45mm instead of 35mm? - Similar Threads | ||||
VP Front Upper Link Mount | Greatscott | Axial XR10 | 25 | 11-27-2011 08:40 PM |
Upper Shock Mount ? | rctoyguy | Losi Mini-Rock Crawler | 6 | 06-25-2009 05:37 PM |
Lower shock mount width? | LAV25 | Losi Mini-Rock Crawler | 2 | 02-05-2009 05:58 PM |
front shock mounting on stock chassis | lohocla | General Crawlers | 13 | 01-21-2007 11:55 AM |
