06-05-2012, 07:11 PM | #1 |
Quarry Creeper Join Date: Mar 2012 Location: Montreal
| Vanquish Chubs/Knuckles
Hi Guys, juste received my vanquish Chubs and knuckles... QUestion about the chubs, they can be set for positive or negative camber. What would you recommend? Also, there is a lot of play between the chub and the knuckle, do you tighten? do you put some blue loctite? Thanks! |
06-05-2012, 09:15 PM | #2 |
| Re: Vanquish Chubs/Knuckles
Just realized I forgot to place the bushing from the hold knuckles, hence the amount of play. All set! |
06-05-2012, 10:42 PM | #3 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Camber isn't adjustable. Caster is adjustable. The top of the chubs should go the rear as far as the hole allows. Thats the the most caster. I use blue loctight.
Vanquish Chubs/Knuckles - Similar Threads | ||||
vanquish new chubs and knuckles | steppinrazr | Axial AX-10 Scorpion | 8 | 04-26-2011 09:57 AM |
