08-16-2012, 07:21 PM | #1 |
Pebble Pounder Join Date: May 2012 Location: California
| Got the bounce !!!
So my dilemma ..... Chaotic Special Lw, crawls great has awesome break over ,pretty good side hill.. But every time I go to bump it over the rear gets a huge bounce but not in a good way also the front seems to be constantly looking for traction ( maybe the surface I am running ) My set up - XR10 Chaotic Special LW Chaotic Ti links Big bores - Doug's cups -mini T pinks - 35 wt oil Vp DH wheels x4 Vp C's and knuckles Vp knuckle weights + 1/4" add-ons No rear weights ( swapped all axle hardware with aluminum) Rover- whites with CI 2 stage foams ( closed cell inner soft outers ) Hr trans cases f/r Rc4wd gears Vp f/r axle top link mounts Hitec 7950th Chaotic Ti straight link Vp rear lock outs Novak Rock Star motors 45t Punk dig Castle bec FXR esc Any suggestions on top link placement on the VP f/r axle mounts ? Thanks everyone Last edited by Subytuner; 08-16-2012 at 08:06 PM. |
08-16-2012, 07:46 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
| Re: Got the bounce !!!
Pics would be very helpful side shots link lengths and mounting points
08-16-2012, 07:49 PM | #3 |
Quarry Creeper Join Date: Nov 2009 Location: Central Arkansas
What foams are you running in those rovers?
08-16-2012, 07:53 PM | #4 |
| Re: Got the bounce !!! Crawler Inovations 2 stage with soft outers Closed cell inners and soft memory outers Last edited by Subytuner; 08-16-2012 at 08:04 PM. |
08-16-2012, 08:22 PM | #5 |
Are they the soft outers with memory tuning rings? Or are they full memory outers?
08-16-2012, 08:22 PM | #6 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Got the bounce !!! Quote:
SOME hop is inevitable. Just happens but if its a gnarly hop...ya should be able to tune it out fairly easy. J.D. | |
08-16-2012, 08:28 PM | #7 |
I have heard of the closed cell inners giving lighter rigs a bit of hop.
08-16-2012, 08:35 PM | #8 | |
08-16-2012, 08:46 PM | #9 |
This may sound strange but I'm going to try and make sense. Put a medium outer in the rear it will reduce the bouncing of the inner due to the increase in resistance of the outer. Since the DH wheels are heavy to begin with you should notice an increase in traction if you put medium outers front and back. This will also decrease the unnecessary tire roll while side hilling.
08-16-2012, 08:57 PM | #10 |
Just to put it in perspective you have 34.38oz (2.15lbs) of weight in your wheels and knuckle weights alone.
08-16-2012, 09:07 PM | #11 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
run a lil heavier shock oil in the rear as well . i had that prob as well an i went with a softer foam in the tire an heavier oil in the rear shocks. had the same prob with my switch an did the same thing with it as well an it stoped |
08-16-2012, 09:36 PM | #12 |
It's funny how different stuff works for different people. I would just try all these great suggestions and see what works for you.
08-19-2012, 07:37 AM | #13 |
| Re: Got the bounce !!! |
08-19-2012, 08:02 AM | #14 |
One more thing. Are your wheels or tires vented?
08-19-2012, 08:11 AM | #15 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Drive smoother
08-19-2012, 09:42 AM | #16 | |
08-19-2012, 11:07 AM | #17 |
08-19-2012, 11:09 AM | #18 |
08-19-2012, 01:43 PM | #19 |
08-19-2012, 02:18 PM | #20 |
| Re: Got the bounce !!! A while ago I was having trouble with the closed cell's venting but since then I have vented the tires, plenty of air comes out and goes right back in at the same rate
Got the bounce !!! - Similar Threads | ||||
Axials with standard foam Vs Losi with Memory foam - bounce test | Mud Puppy | Tires and Wheels | 3 | 10-24-2010 11:10 AM |
no suspension bounce? | spacephrawg | Axial SCX-10 | 12 | 06-30-2010 09:03 AM |
Bounce | Rokslayer | General Scale Talk | 4 | 11-15-2009 02:05 PM |
Bounce-o-meter !35%! | DISTURBIN' tha PEACE | Chit Chat | 28 | 10-11-2006 12:29 AM |
