08-16-2012, 10:09 PM | #1 |
Newbie Join Date: Jan 2008 Location: Loveland
| What's the latest dig opinion??
I've just received a new, partially built XR10 from a friend going through a divorce. He had gotten a funky dig switch thingy from Dan @ Finishline. (it's got two switches mounted on plastic that are actuated by a micro servo). I would consider using it if I had some instructions.... Or... Most of what I've seen and searched for advice on 3ch systems is pretty old. And I would like a fresh take on what is working for you guys. I've got a DX3R or a DX3E to choose from for a radio. Two 55T Holmes Hobbies motors. and a Tekin FX-R pro ESC, as well as the aforementioned dig thing. I've got tons of other add-ons to tweek and finish the thing but would like some advice from folks who have actually tried different dig controllers locally.(Colorado) I have no interest in buying another radio to run dual esc's. nor do I have many intentions in competing seriously. I've competed in the past way back in the day with my AX-10 and once when I got my Losi comp. I'm not a noob here but I've been out of the loop for a bit building a KOH buggy. Any help would be appreciated and I'll try not to be a stranger around these parts. I've got 4 of these damn things now, plus two of the stupid Losi micro crawlers!! |
08-16-2012, 10:38 PM | #2 | |
Quarry Creeper Join Date: Jan 2011 Location: westminster
| Re: What's the latest dig opinion?? Quote:
08-16-2012, 11:13 PM | #3 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
I run a punk with a single FXR and it works fine. A buddy of mine ran the mechanical dig you are talking about and that worked fine also. Both will need a 3 position aux switch for full use. I am running a radio with a 2 position switch so I can only lock out my rear as of right now.
08-17-2012, 03:21 AM | #4 |
Quarry Creeper Join Date: Sep 2011 Location: On PayPal trying to make funds appear.
I ran an fxr as well as a Brxl with a punk dig. Honestly, I loved it. I would tell you to saw money and get a radio with mixing and run dual esc. It took me an hour to get used to it and actually use it kind of effectively, but wow I love it If it is 1 esc only, then get a punk dig!!! |
08-17-2012, 05:35 AM | #5 |
Do a search for "servo dig" in the electrical forum, likely lots of diagrams there. I started crawling with a CC Mamba Max and servo dig on a 2.2 Bully. It worked OK on a Futaba 3PM-x. Later, I went to a WantAmix adapter and dual Mamba Max's, way better. I would look to see if the WantAmix works on your Spektrum (it works with some) and then get a 2nd FX-R. You then get front & rear dig as well as proportional. As to other dig units, I heard issues with service for Punk Digs, so some searching in the electrical forum may yield some opinions. |
08-17-2012, 10:33 AM | #6 |
Quarry Creeper Join Date: Dec 2010 Location: Phelan California
I had a dx3r with punk dig and fxr combo and it was good, eventually went the dual fxr and wantamix adapter and it was a lot better, best has been dual sidewinder micros and futaba 4pl. The change in performance from the dig to the dual esc adapter was big and really easy to get use to but had a few small quirks that annoyed me in comps so I went to the 4pl and micros and it performs the same as with the adapter but a little more intuitive when making adjustments on the fly. If I knew for a fact I wouldn't be comping very much Id go punk dig, easy to use and nearly idiot proof. If you could possibly catch that comp itch then get the wantamix |
08-17-2012, 10:00 PM | #7 | |
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Here are a couple snapshots of the switch. I hope I can get some help wiring this thing. In the future I'll most likely go with the Punk Dig. It seems to be the most popular. (For now) I'll look into getting a 4ch radio down the road. This is probably pretty much overkill for what I want out of it, but i figure I can work on building my scaler a little more crazy now that ive got this. | |
08-18-2012, 12:59 PM | #8 |
K lemme look at my old setup and ill post up !
08-22-2012, 10:21 PM | #9 |
Any luck with those schematics?
08-23-2012, 02:33 PM | #10 |
Rock Stacker Join Date: Sep 2008 Location: Gilmer, Tx
From the pics you posted, the short red/black wires on dig goto the esc and the long wires from each switch goto each motor. Plug dig servo into the 3rd channel of rx and trim to neutral. I believe that the DX3R has a 3 position 3rd channel, so you will have front dig/4wd/rear dig.
08-24-2012, 06:57 AM | #11 | |
Thanks for the help on the wiring, I'll mock it all up and test it before final soldering. From looking around on the forum, It appears I should immediately upgrade the upper links for sure and the lowers would be a good idea as well. Does that sound about accurate? I'm finishing a car right now for a car show on sunday, and after that I can devote some more time to 10th scale | |
08-24-2012, 11:51 AM | #12 |
I haven't actually used the stock XR10 chassis so I can't help you there. I'm currently building a XR10 using a Y-town Secret chassis. I sold my 4PK a while back, so I'm gonna try using my trusty M8 with a wantamix and dual fxr's. Proportional 3rd channel should be a nice feature with the wantamix.
08-24-2012, 01:09 PM | #13 | |
I run a Futaba 3PM-x & a WantAmix on my 2.2 Bully, yes, it works well. You will like it. | |
08-24-2012, 10:23 PM | #14 |
| Re: What's the latest dig opinion?? |
What's the latest dig opinion?? - Similar Threads | ||||
my opinion on new school rocker dig | rccrawler66 | RC4WD Bully | 3 | 12-21-2010 12:50 PM |
Opinion on dig | moabax | EnRoute Berg | 44 | 03-11-2009 11:37 AM |
Need your opinion: RC4WD R2 Dig | J O N | Axial AX-10 Scorpion | 2 | 02-12-2009 09:42 AM |
DIG Opinion | Mini | Axial AX-10 Scorpion | 60 | 02-03-2009 09:18 AM |
Post Your Opinion About Dig!!!! Yes/no | JIA's Dad | Chit Chat | 23 | 03-27-2007 01:37 PM |
