08-19-2012, 09:13 PM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
| Vanquish slw 1.0 ??
Might sound like a dumb question, but when I order a new set of slw 1.0 rims.. Do I need 2 bead lock rings per rim or just one like the stock wheels?? Also looking for a suggestion for hub widths as well before I order? Stock XR10 with white Rovers and mods in the mail! Thanks guys! Sorry! And will the stock xr10 bead lock rings work with these?
08-19-2012, 09:20 PM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Stock beadlocks have a different diameter than VP ones. When you order VP ones, they go as 4 for a pair of rims.
08-19-2012, 09:22 PM | #3 |
475 & 600 are generally the hubs used with the XR.
08-19-2012, 11:25 PM | #4 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: Vanquish slw 1.0 ??
You will need to order: 2 of these in which ever style you choose- SLW V1 and 2 of these, again in your choice of style, to suit the wheel SLW Beadlock Rings To make a set of four wheels. as for the hubs, they are more of a personal decision. Do you like a wide or narrow rig. personally I run 600's and 725's from memory. you would be safe to order 475's, 600's and 725's that way you can pick a combo that you like. |
08-20-2012, 09:24 AM | #5 |
Great!! Appreciate all help guys!!
