08-23-2012, 07:24 PM | #1 |
Pebble Pounder Join Date: May 2012 Location: California
| Boss claws
Getting some boss claws for my chaotic special lw, any tips on shaving the sidewalls ? An how does this affect the performance ? Any tips on foams to run in these ? Thanks |
08-23-2012, 09:07 PM | #2 |
| Re: Boss claws
Use a die grinder or 90* flapper disk on your dremmel. It will soften up the sidewalls. CI 5.25" Closed Cell foams....the outers will depend on the weight of your truck and personal preference. |
08-25-2012, 07:28 PM | #3 |
Quarry Creeper Join Date: Apr 2012 Location: Talladega, AL
| Re: Boss claws
A belt sander makes very quick work or it. A 4.5" angle grinder with a flap disc works well also. With the dremmel you will be there for a while but it works as well.
08-25-2012, 07:31 PM | #4 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Boss claws I use a 4.5" angle grinder with a 80 grit flapper disc and it makes it look really nice Last edited by EverettY; 08-25-2012 at 08:09 PM. |
08-25-2012, 07:33 PM | #5 |
| Re: Boss claws I've found the belt sander to be too fast and uncontrollable. I like to cut the lugs as short as possible (which lessens the dremmel work), then use a dremmel which give me more precision...
08-25-2012, 07:40 PM | #6 | |
But make sure the drill is on low speed. Those babies will blow up. Sent from my EVO using Tapatalk 2 | |
Boss claws - Similar Threads | ||||
Boss Claws | OKJeepin | Axial AX-10 Scorpion | 13 | 01-15-2012 10:19 AM |
