10-13-2012, 02:48 AM | #1 |
I've got a STUBBY! Join Date: Apr 2011 Location: Newcastle Australia
| Josh's xr10 "Secret agent 3.5"
Hi guys I have been on here for a little while now and figured it was time to show you my junk. specs as of right now are Front axle: Axial plastic housings w/ 4xford insert mod Vp Chubs, caster 1 spline past standard Vp Wraith Knuckles NCD knuckle weight holders w/ 2 half rings Vp transmission case Vp upper link mount Axial lightweight gears w/ enlarged holes to lighten more Axial Ti final drive shaft Chaotic bent tierod Chopped BWD motor Sav'r Soon to have SDS 300HD Rear axle: Axial plastic housings w/ 4xford insert mod Axial plastic lockouts Hulksta 5mm Ti shafts Vp transmission case Vp upper link mount Axial lightweight gears w/ enlarged holes to lighten more Axial Ti final drive shaft Chopped BWD motor Sav'r Chassis: YTC Secret agent 3.5 w/ .25mm carbon fibre panels Chaotic Crawlers Ti Links w/ revo & jato rod ends and Aluminium balls 3.5 inch Traxxas bigbores lathed down, mounted with Dlux stand offs Mini T silver rear springs all round w/ Jeepin doug cups Wheels: YTC carbon fibre glue on rims w/ 725 & 850 Vp SLW hubs Shave and trimmed Boss Claws w/ C.I 5.25 double deuce foams (soft front, med rear) Electronics: Team Brood 45T Apocalypse HHK-S w/ all lightweight options Dual Holmes Hobbies Brxl's smashed by Creationfab Castle 10A BEC Hitec 7950 running 7.4v How i bought it as a roller New motors in preparation for the dieting phase Motor plates drilled to lose a few grams Shock bodies lathed down Vp hubs lightened I cut my own transmission covers from 1mm carbon fibre steering arm setup w/ wraith knuckles I made my own battery mount to take dan(hulkstas) 450mah 4s batteries he built me, with the extra caster my tyre tries to eat the battery on the Rowdy mount As it sits right now she weighs in at 1814grams Hope you guys enjoy Josh Last edited by Joshie; 10-13-2012 at 05:43 PM. |
10-13-2012, 03:08 AM | #2 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
| Re: Josh's xr10
Looks good! |
10-13-2012, 09:49 AM | #3 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: Josh's xr10
Nice build man, that thing is light |
10-13-2012, 03:42 PM | #4 |
| Re: Josh's xr10
Thanks camo shaved boss claws all round front: 119grams ytown glue on wheels 850 hubs C.I DD foams closed cell inner soft outer w/ med tune ring rear: 120grams ytown glue on wheels 725 hubs C.I DD foams closed cell inner medium outers My motors are back after being rebuilt by hulksta, first item on the list was to stop the lathed cans forming surface rust again, fixed this with some clear nail polish. Whilst browsing RCC I came across the mod Robbob did to his VP highsteer arm to reduce the servo horn throw and still get full travel so i have done this. Also changed up my skins to some .25mm blue carbon fibre sheet i picked up a few weeks back. last changes that have been made were a few SS screws changed to Ti ones and also the Al hollow balls being used to space out my upper links at the chassis end are now replaced by axial plastic balls out of my exo kit. some pics of the steering Josh |
10-21-2012, 02:08 AM | #5 |
| Re: Josh's xr10 "Secret agent 3.5"
So we had our last comp of the northcrawl rc points table today, happy say i took the win and guarenteed me 2nd in the points table. midway through the 2nd course my front diff made a bad noise, pulled it down for a re grease tonight and found my 22t final drive gear minus 2 teeth here is some pics of my rig on course 1 The album with course 1& some of 2 in it october northcrawl comp pictures by turbo_deo - Photobucket josh Last edited by Joshie; 10-21-2012 at 03:40 AM. |
10-21-2012, 02:32 AM | #6 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| Re: Josh's xr10 "Secret agent 3.5" |
10-21-2012, 03:24 AM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: brisbane
Orsome pics mate, where was the comp held at? Steve |
10-21-2012, 03:38 AM | #8 |
10-21-2012, 03:45 AM | #9 |
Rock Crawler Join Date: May 2012 Location: Australia
Saw this thing in action today it works so good. Josh, what is the outside diameter of your big bore shocks after machining? I might shave some weight of my rig, gotta try challenge you some how |
10-21-2012, 03:54 AM | #10 |
RCC Addict Join Date: Jun 2009 Location: Australia
Do you comp with the Northern NSW part of TCP? Sent from my GT-I9100T using Tapatalk 2 |
10-21-2012, 03:59 AM | #11 |
10-21-2012, 06:49 AM | #12 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
Which make of final gear is that? Stock? Trying to decide on what gear set to go with.
10-21-2012, 12:38 PM | #13 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Josh, are you using a Chaotic tie rod ?
10-21-2012, 01:47 PM | #14 | |
| Re: Josh's xr10 "Secret agent 3.5" Quote:
I'm using the chaotic bent tiered at the moment, but it is a touch long and is giving me more toe in then I would like, I have a Nordic crawler tiered here I am going to try when the front diff goes back together. Josh | |
11-10-2012, 06:45 AM | #15 |
So a small update: My new final output gear arrived through the week so I got that fitted up, I got my chaotic bent tierod changed out for the Nordic crawler tierod. I also have changed out the brxls for a pair a smashed micro sidewinders installed on a rowdy electrics tray I also had some 3/16 al tube show up so I can make some chassis cross braces and maybe try it out as links. Josh |
11-17-2012, 12:43 AM | #16 |
Rock Stacker Join Date: Apr 2012 Location: NEWCASTLE
shame about today mate, hope you get your gremlins fixed up easily enough, looks awesome tho, really making me want to build one
11-20-2012, 02:54 AM | #17 |
So today the postie was very friendly and dropped off these Here is a comparison with the vanquish VVDS Had a great day on Sunday at the last (my first) cANZ round only a few casualties, my front motor sav'r snapped off so new ones have been ordered, and after chatting to hulksta I have ordered some alum scx10 shocks to replace the big bores. Josh |
04-10-2013, 01:43 AM | #18 |
Updates please Joshy Sssshhhh |
04-10-2013, 03:55 AM | #19 | ||||||
here is some updates to catch this thread upto date Quote:
Josh | ||||||
04-10-2013, 02:37 PM | #20 |
Quarry Creeper Join Date: Feb 2011 Location: Fenton, Mi
Nice work man! I also recently changed my sa3.5 berg over to a body and can't be happier! Very nice build man, keep up the good work!
Josh's xr10 "Secret agent 3.5" - Similar Threads | ||||
Josh's TOUGH truck 1.9 hilux | rocksteadily | 1.9 Scale Rigs | 91 | 04-16-2013 09:40 PM |
Josh's tb02 drifter crap | rocksteadily | Non Crawler RC's | 5 | 07-21-2012 10:28 PM |
Josh's tj ttc | upoveryou | 2.2 Scale Rigs | 3 | 03-16-2011 02:35 PM |
josh's scx-10 (first scaler) | josh97 | Axial SCX-10 | 6 | 04-22-2009 09:19 AM |
