11-05-2012, 09:17 AM | #1 |
| Wiil the VP bushings work with the Axial HD motorplate?
Just checking will the Vanquish XR10 Transmision Bronze Bearing kit work with the Ax30787 Axial Heavy Duty Gear Plate Hard Anodized XR10? Is there a less expensive alternative? Thanks, John |
11-05-2012, 09:39 AM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Wiil the VP bushings work with the Axial HD motorplate?
For the same price you can get the RC4WD bearing conversion kit. Transmission Bearing Conversion Kit for Axial XR10 |
11-05-2012, 10:41 AM | #3 |
I already have the HD motor plates, I got the axles used and the bearing are about done.
11-05-2012, 11:21 AM | #4 |
The Axial motor plates use 9mm bearings so the VP bushings will not work.
11-05-2012, 12:10 PM | #5 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
For the price of the VP bearing kit you could pick up a whole new motor plate with 10mm bearings in it. |
11-05-2012, 03:13 PM | #6 | |
Quarry Creeper Join Date: Dec 2004 Location: Gardnerville
| Re: Wiil the VP bushings work with the Axial HD motorplate? Quote:
11-05-2012, 05:52 PM | #7 | |
Rock Crawler Join Date: Jun 2008 Location: sacramento
Pretty sure they are 8mm. The bronze kit was a quick fix for when the xr-10 just came out. The 8mm bearings were blowing putting bearings into the case and doing more damage. The bearing bronze material we used was a tru bronze. A huge difference to the casted bronze that tamiya and traxxas is selling. The bronze is prob better than bearings. Since for one it will never just fail. You would have to put a lot of drive time on them to begin to see wear. | |
11-05-2012, 05:57 PM | #8 | |
11-05-2012, 06:25 PM | #9 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
| Re: Wiil the VP bushings work with the Axial HD motorplate? |
11-05-2012, 09:51 PM | #10 |
Pm sent.. got bearings not using John..
11-06-2012, 04:29 AM | #11 |
Thanks Troy, PM back. |
Wiil the VP bushings work with the Axial HD motorplate? - Similar Threads | ||||
ax10 motorplate question | kev_gti5 | Newbie General | 6 | 08-27-2010 06:33 PM |
an axial work horse | NeXt559 | Chit Chat | 4 | 08-16-2008 08:57 PM |
