Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Cjsmith's Chassis Flip to Sudo Pro for 2016 Season
Old 03-23-2016, 06:13 AM   #1
Default Cjsmith's Chassis Flip to Sudo Pro for 2016 Season
I like starting new projects before finishing old projects, so here goes my next one.
I won a Dravtech Sudo Pro chassis last year at the Northeast National Championship held by the Eastern Pa Rc Crawlers. Figure it is time to give it a shot.
I am switching to the Sudo pro from a secret agent.
Specs:
Dravtech Sudo Pro Chassis
Sudo Pro links from Dlux
Axles covered in Vp
Matched 35 t Holmes motors
Dual sidewinders smashed
Bec
7950TH
Scx10 shocks with Mini T springs
Airtronics RX/TX
cjsmith4 is offline   Reply With Quote
Old 03-23-2016, 06:25 AM   #2
Default Re: Cjsmith's Chassis Flip to Sudo Pro for 2016 Season
Chassis completely disconnected from the axles. Now just have to get the electronics out. They are all hard wired with no easy connections so I plan to take the top of the cab off and then I will slip the electronics out the top and then into the new chassis.
Old 03-23-2016, 06:58 AM   #3
Chassis and axles are apart. Found a few solders I need to fix while it is all pulled apart. Going to fix those before adding the new chassis.
Old 03-23-2016, 08:30 AM   #4
Thank you to the folks at DravTech for creating and providing such an awesome chassis. This was quite a win for a raffle at a comp.
I started by tracing the side plates on paper so I can attempt to make my own panels that will match my sporty whenever that gets completed.
Old 03-23-2016, 09:12 AM   #5
Decided to switch out the aluminum screws with red anodized screws I had laying around that fit the theme since we all know sticking to the theme is important. I had enough of the 8mm screws to swap in the red ones. I found the 16mm screws online at fastener express so I'll order them.
I can't find the M3 X 20mm or the M3 X 25mm anodized screws online anywhere. Anybody know where I can find these longer lengths in red??
Old 04-09-2016, 09:16 AM   #6
The sudo is beginning to grow legs.
Old 04-13-2016, 06:01 AM   #7
Got the rest of the rod ends I needed to complete this chassis flip.
I haven't tested the electronics to make sure they work yet because they worked before I switched them over so I'm hoping they still work now that the chassis is complete.
Also got to measuring and made some templates for the body panels. I traced the side panels before out them on the chassis. This will be roof and hood.
Old 04-24-2016, 08:57 PM   #8
The sudo ran awesome today in its first outing. Pulled a second behind Winner123 at one of the toughest comp spots we have. Still a few minor things to work out like weights but I was super happy with the results. Somehow, it didn't even end up on its lid today.
Old 04-24-2016, 09:36 PM   #9
Great driving today!
Jslick is offline   Reply With Quote
Old 05-16-2016, 11:47 AM   #10
I was really happy with how the sudo performed this weekend at the New England Monster Showdown. Came in 15th out of a very talented pool of drivers even after a big DNF due to a loose grub screw on the motor pinion.
Old 09-11-2017, 06:38 PM   #11
I finally got a full season in on this rig and it was a great one! Pulled out a second in our last comp of the season at St. Peter's and a third for the whole season behind JSlick and Troy. Thanks for a great season EPA Rc Crawlers.
Cjsmith's Chassis Flip to Sudo Pro for 2016 Season - Similar Threads
KCRC 2016 Season Schedule the DMG Missouri 117 12-13-2016 11:08 PM
Boston Crawlers - 2016 Outdoor Season BC-Brian Massachusetts 9 06-12-2016 01:05 PM
EPARCC 2016 Season Jslick Pennsylvania 5 05-05-2016 02:17 PM
S.W.R.R.C. 2016 Season teamvaladezhobb New Mexico 1 01-30-2016 06:53 PM
