10-20-2016, 07:52 PM | #1 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Xr brushed motors
I'm looking to see what the guys that can leap a 1ft gap on their moa's are using please help...also needs low speed creep Sent from my HTC One M9 using Tapatalk |
10-20-2016, 11:20 PM | #2 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
| Re: Xr brushed motors
30T holmes hobbies pullers or 30T team brood conflux.. If five slot on the HH motors you will need 16T, with those motors you can jump gaps and have perfect low speed control |
10-21-2016, 09:51 AM | #3 |
Is that the 4 or 500 he motor. I have integy motors now...I believe they are 440 cans Sent from my HTC One M9 using Tapatalk |
10-21-2016, 11:18 AM | #4 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
I run the Brood Stubbies 35t which are like a 30t standard 540 can motor. They are extremely powerful with great low speed control. Some good conflux's or even his new line of motors the Genesis or Nexus. My bro uses Holmes and has had good luck with both the 400 & 500 motors. |
10-21-2016, 12:38 PM | #5 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
35T Brood Stubbies or 30T Brood Conflux will get the job done. |
10-21-2016, 02:05 PM | #6 |
RCC Addict Join Date: May 2012 Location: Folsom
If you're not exactly sure about what you want dont buy anything thats costs more than $50-65 per motor. Figure out at that price point or lower what you like and what you want.... then you can spend money... Nothing is worse than spending $400 bucks on motors that sit in you parts bin.... trust me....been there done that. |
10-21-2016, 03:46 PM | #7 |
Thanks for all the good advise guys...I'm not sure if I have 400 or 500..I'll attach a pic so you can see Looks like 35mm Sent from my HTC One M9 using Tapatalk |
10-21-2016, 07:40 PM | #8 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
That's a 540 can. Sent from my SAMSUNG-SM-N900A using Tapatalk |
10-21-2016, 07:59 PM | #9 |
That dude. That definitely helps Sent from my HTC One M9 using Tapatalk |
12-05-2016, 12:57 PM | #10 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
I am about to pull the trigger on a matched set of Team Brood Apocalypse 35t/HHK-T's. Can you guys school me on timing? I'm lost!!! -Nasty Sent from my iPhone using Tapatalk |
12-05-2016, 01:46 PM | #11 |
| Re: Xr brushed motors |
12-05-2016, 02:03 PM | #12 |
I did, and he set most do 6. But the motors have to be installed correctly. I guess my question is, what does timing the motors do for me, and if timed, how does the install differ from an untimed motor. I don't want to mess this up man!! -Nasty Sent from my iPhone using Tapatalk |
12-05-2016, 02:10 PM | #13 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Timing adds more power, but also helps the motor arch less, so they run better. However, one motor is timed in reverse....so if you mix them up, both motors will be running with retarded timing (bad bad bad). It's simply important to install the motors in the correct spot (typically reversed motor in the rear) to prevent this from happening....often, people install them correct, but they run backwards so they swap them.....typically this is due to an ESC or Radio setting, which should be what is changed to fix them. This why people often get motors timed at zero, which elimantes this problem pretty much, as regardless of install, they will be at zero either way. Later EddieO |
12-05-2016, 02:16 PM | #14 |
More timing equals more RPM less timing equals more torque Sent from my HTC One M9 using Tapatalk |
12-05-2016, 07:29 PM | #15 |
Sent you a pm Eddie...need some advice on the motors that best fit my needs. Thank you sir in advance Sent from my HTC One M9 using Tapatalk |
12-13-2016, 03:40 PM | #16 |
Look what was in the mail today... Time to get these into the rig. Thanks for the recommendations guys. Cheers, -Nasty Sent from my iPhone using Tapatalk |
12-13-2016, 04:50 PM | #17 |
Very nice nasty...time to break stuff Sent from my HTC One M9 using Tapatalk Last edited by THX_138; 12-20-2016 at 06:39 PM. |
12-13-2016, 05:39 PM | #18 |
You know that is right. 149 r/c worx's Team Driver |
12-19-2016, 08:09 PM | #19 |
Team Brood Apocalypse matched and timed motors installed. Huge difference running with quality motors. Thanks Eddie and Dasco for the help. On to shocks, c-hubs, and knuckles!! Sent from my iPhone using Tapatalk |
12-20-2016, 05:12 AM | #20 | |
| Re: Xr brushed motors Quote:
Sent from my HTC One M9 using Tapatalk | |
Xr brushed motors - Similar Threads | ||||
brushed motors | Smiles | Newbie General | 5 | 06-19-2011 02:45 PM |
No more brushed motors for me! | Scattman | Chit Chat | 3 | 07-04-2006 03:36 PM |
