Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Sudu Mod 3d
Old 04-01-2017, 08:05 AM   #1
Default Sudu Mod 3d
Just wondering if anyone out there is running the Sudu Mod 3d on their XR axles and how it's been working out for them, been eyeballing this chassis for a while now but haven't seen any build threads yet. was thinking bout getting a new bully 2 kit and letting my son have the chassis for his XR10 and then ordering the Mod 3d chassis, but iv'e still got a good set of XR10 axles i'm not using, which are lighter, so figured i'd skip over the bully 2 axles for now and just set it up on XR10 axles. Any info would be nice.
motoj550 is offline   Reply With Quote
Old 04-01-2017, 09:35 AM   #2
snapon boy's Avatar
Default Re: Sudu Mod 3d
They are very nice I saw some video of it at worlds on utube
149 r/c worx /scalerfab Team Driver
snapon boy is offline   Reply With Quote
Old 04-03-2017, 02:23 PM   #3
Nobody huh, well i went ahead and ordered one. i guess i'll be the 1st one to do it. i'll start a build thread on it when i gets here in couple weeks.
Old 04-03-2017, 09:46 PM   #4
So far I only know one who has done it in Finland. Seems to be working just as well as with the Bullies. You should be just fine with it.
Zarizi Tech is offline   Reply With Quote
Old 04-13-2017, 02:57 AM   #5
R_2
Another one is coming here As soon as I get that project started
R_2 is offline   Reply With Quote
Old 04-13-2017, 10:19 AM   #6
Once you do some weigth removal from the bully2 diffs you can get them very close to the weight of the XR diffs. A couple simple mods is to drill the tubes out, add alum screws and your just about there
chevotafun is offline   Reply With Quote
Old 04-13-2017, 05:42 PM   #7
still waiting on my chassis, been almost 2 weeks, getting very anxious, can't wait to get this build going. have just about everything i need, even got Master Dlux's brass knuckles and set of upper and lower links to go with it.
Old 04-20-2017, 03:36 PM   #8
oh yeah! tracking has it in Chicago, yes yes yes
Old 04-24-2017, 04:15 PM   #9
I got my new Sudo 3D sitting in the bag waiting to build. Took the XR out for the last run as a stock XR and heard a funny popping sound in the rear end. Pulled it apart and broke the 22T gear. I am on the hunt for that gear now but not having much luck.
Keep us posted when you get yours and how the change over goes.
Grape-ape.mia is offline   Reply With Quote
Old 05-01-2017, 12:46 PM   #10
Anyone have any link lengths (eye to eye) for this chassis on xr10 axles, seem to be having problem getting them.
Old 05-01-2017, 01:16 PM   #11
R_2
Front lower 128mm, rear lower 157mm. Not probably 100% accurate but that`s the lenghts I`m making them
Old 05-01-2017, 02:18 PM   #12
my last set that Dlux sent me are:
front lowers - 120mm
rear lowers - 149mm
front uppers - 110mm
rear uppers - 146mm
with this i'm at 11 7/8" wheelbase, i'm runnin' 91mm scx10 shocks and the front links are so short that i can't get ride height low enough and my Barry's rc carbon electronic mount is hitting the front lower links. and then my caster is level instead of tilted back and my servo tilted way forward indicates the front lowers are too short. i'm at 5 1/4" center of skid to center front axle and 6 5/8" center skid to center of rear axle which means i'm roughly 1 3/8" forward bias with the chassis.
Old 05-02-2017, 08:15 AM   #13
Unhook your uppers front and rear at the axle. Then check your wheel base.
The combo of long uppers and short lowers can mess with caster and servo angle. Just gotta figure out which is wrong.
Curcal is offline   Reply With Quote
Old 05-02-2017, 08:40 AM   #14
Custom Carbon Fiber
Robbob's Avatar
Take the springs and the esc plate off too when you do the upper links, compress your shocks so they are down as far as they will go. Set the belly on something so the wheelbase is at 12.5 and check your upper links.
If possible I would lengthen then front lowers to help clear the esc plate, or make a shorter one.
Robbob is offline   Reply With Quote
Old 05-02-2017, 09:19 AM   #15
R_2
If those are Dlux links for Sudu pro for XR10 then swap one link ends (ie chassis side for both F/R) to the longer trx link ends (jato) and you are set
Old 05-02-2017, 11:46 AM   #16
thanks for the responses guys, Dlux is working on it as we speak. while waiting last night i used some ready rod and rough bent some rear lowers and set it up with 157 rear and 128 front and with no shocks and uppers it was at 12 7/8". so i left the front at 128 and went back to the same lengths on all the others that Dlux sent me and now sitting perfectly at 12 1/2" wheelbase. so i think all the links Dlux sent me except the front lowers is what i need and then change the front lower from 120mm to 128mm and should be good. ( pic #1 ) and kinda mocked up the same style bends on the rear lowers. Pic 2 showing 1 3/4" compressed ride height, pic 3 showing bout 3 1/2" full droop, pic 4 showing bout 3" running ride height. pic 5 showing wheelbase at just barely under 12 1/2". pic 6 showing chassis bias between axles. also have plenty room now for my electronics mount.
Sudu Mod 3d - Similar Threads
Everett's SuDu Mod 3D EverettY RC4WD Bully 71 06-01-2021 10:34 PM
Information for SuDu Mod 3D and Bully2 Electronic Tray users Dravpnir RC4WD Bully 1 02-12-2017 11:44 AM
Bluerocks SuDu Pro Mod. build Bluerock108 Axial XR10 46 02-08-2017 12:57 AM
