Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Transmitter help
Old 11-29-2014, 06:54 PM   #1
Default Transmitter help
I have had my Yeti XL for 3 days and at the start of my 4th run the transmitter would only work from 10 feet away. I made sure the antenna in the Yeti was not damaged as well as replacing the batteries in the transmitter. Has anyone else had this issue? Any ideas on how to fix the issue? Since the car came out of the box it would spark when hooking up the second battery. Not sure if this could be a cause or not. Any help would be appreciated.
FLCErik is offline   Reply With Quote
Old 11-29-2014, 07:15 PM   #2
Default Re: Transmitter help
I'm on day 2 of owning mine. It did the same thing. It's like it losses the bind between the rx and tx. I switched the rx to a spektrum and bound it to my dx3r. And it still kinda acted funny.
axman is offline   Reply With Quote
Old 12-01-2014, 09:13 AM   #3
I called customer support and they are sending me a new transmitter and receiver.
Old 12-01-2014, 10:23 AM   #4
I'll do the same.
steve.hiehn is offline   Reply With Quote
Old 12-01-2014, 10:34 AM   #5
Just so you know, that spark is normal when you connect the battery. Just an FYI
Jsouza1980 is offline   Reply With Quote
Transmitter help - Similar Threads
Stick transmitter vs pistol grip transmitter D19er Electronics 3 03-05-2014 09:52 AM
transmitter help DSmith9669 Redcat Crawlers 3 04-13-2012 05:49 PM
Transmitter martinez34 Electronics 2 04-03-2010 12:25 PM
What is everyone using for a Transmitter? cliffdawg Team Losi Comp Crawler 47 03-17-2010 03:31 AM
