Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Yeti XL Motor options?
Old 01-14-2015, 03:12 PM   #1
Default Yeti XL Motor options?
Seen the new kit on the way so was curious about this.
on 4S usage, how has temps been on the RTR motors which appear to be castle 1515s?
Anyone try a buggy sized 1/8 motor instead?
Cainlord is offline   Reply With Quote
Old 01-14-2015, 03:15 PM   #2
Default Re: Yeti XL Motor options?
I have a tekin 1700 I am throwing in my roller this weekend.
wrightcs77 is offline   Reply With Quote
Old 01-14-2015, 04:16 PM   #3
buggy or truggy sized?
Old 01-14-2015, 04:21 PM   #4
Go truggy [4038] size if you choose a T8 for the XL. The buggy motor would be stressed to push this monster around.
Ty@Tekin is offline   Reply With Quote
Old 01-14-2015, 04:26 PM   #5
yeah I got a Tekin truggy motor sitting here on the ready too Gen2 2000kv, very beastly.
Old 01-14-2015, 06:44 PM   #6
I have the truggy motor, the 4038.
Old 01-14-2015, 08:24 PM   #7
I'm normally a Tekin guy but I like the Yeti XL RTR combo for the simple reason it allows for 4s-6s operation, your not locked in.
SteveC6R is offline   Reply With Quote
Old 03-03-2015, 06:00 AM   #8
I have the same question so I will be looking out for how the Yeti XL performs with a lower kv motor.
For my build I was planning to go a littel cheaper with the electronics (except the servo of course) and my thought was a Hobbywing 1800kv (4274) or a Leopard 1600 kv (4082), or even a Leapard 1480kv (4092) paired with a Hobbywing 150a waterproof ESC.
My thought is that those set-ups would have enough speed to have fund with, while still being able to crawl a little.
Any thoughts/advice on those motors?
Does anyone know if a 92 mm (Leapard 1480kv) motor would fit?
JJHall is offline   Reply With Quote
Old 03-03-2015, 06:26 AM   #9
Default Yeti XL Motor options? - Maximum can length/width?
After my last posting, it occurred to me that I would really like to ask someone who has the Yeti XL to tell me how much space, if any, there is around the motor they are using (for reference, I think the RTR motor is about 40mm x 75mm)
Can a kind souls with a Yeti XL and a ruler let me know what the maximum can length/width is for this vehicle?
I am thinking that 1800kv would definitely fit, the 1600kv would probably fit, and the 1480kv would probably NOT fit, but I have never seen one of these in person so I don't know...
Old 03-03-2015, 01:20 PM   #10
Tekin RX8 and sensored tekin motor
Angus_Beef is offline   Reply With Quote
Old 03-03-2015, 07:54 PM   #11
Agree. Plus I really can't think of a single complaint about the RTR combo. I've run 4s and 6s, both with zero issues. 6s is ridiculously fun!
Terrible1 is offline   Reply With Quote
Old 03-03-2015, 07:59 PM   #12
Chalk me down for this as well.
imthatguy is offline   Reply With Quote
Old 03-06-2015, 08:27 PM   #13
Default Re: Yeti XL Motor options? - Maximum can length/width?
i have a 4092 leopard motor and it has a couple MM left before it hits the back.
cruz1383 is offline   Reply With Quote
Old 03-08-2015, 02:25 PM   #14
With the kit version and the rear sway bar installed it limits the length of the motor. The sway bar runs behind the motor. I have a Leopard 4082 1600kv and it fits with a couple mm to spare before hitting the rear sway bar. So that is pretty much the longest motor that will fit unless you want to take the sway bar off. Then you could go with a longer motor.
BTW I chose a hobbywing 4074 2200kv sensored motor I had here from another project that had been parted out. Should be plenty of motor and I wanted the sensored for smoother start ups. I havent run it yet (still finishing the kit build).
jhautz is offline   Reply With Quote
Old 03-08-2015, 11:08 PM   #15
Who's gonna be the guinea pig for this?
ednerin is offline   Reply With Quote
Old 03-10-2015, 01:55 PM   #16
Awesome, that is exactly the information that I was looking for, thanks!
I am hearing nothing but good things about the 2200kv in this vehicle, I just have a feeling that for what I want, which is a bit of trailing/crawling/speed rolled into one, a lower kv might be the way to go. It seems to me like the 1600kv 4092 might be ideal...
Old 03-10-2015, 01:56 PM   #17
That's good to know, thanks for responding!
Old 03-12-2015, 08:14 PM   #18
Going Tekin 1700kv 4038 running double turnigy 3000mah 5s 30-40C lipo in parallel to give me 6000mah at 18.5 volts....no idea what gearing will end up so I bought a few different size options and will decide from temps.
chewie is offline   Reply With Quote
Old 03-12-2015, 08:17 PM   #19
Do you have yours built...wondering what spur and pinion gears you are looking to run?
Old 03-15-2015, 10:01 AM   #20
Still wondering if this has been run and what gearing you used?
Yeti XL Motor options? - Similar Threads
Motor options jayrod24ky Axial Yeti 2 11-09-2014 11:56 AM
Axial Yeti: Aluminum Roof Options CarterFab Axial Yeti 0 08-01-2014 08:47 PM
motor options? bullas1022 Losi Mini-Rock Crawler 18 01-23-2014 03:01 PM
Motor options........well maybe!!!! Stealthracing Redcat Crawlers 5 04-20-2010 09:40 PM
New motor options aussie_N_B Tamiya Txt-1 and Juggernaut 6 09-19-2006 03:40 PM
