01-30-2015, 02:36 AM | #1 |
Newbie Join Date: Jan 2015 Location: Malaysia
| Yeti XL to 17mm hex conversion
Guys, I did the search on this forum, and googled everywhere, and I think I've concluded that these are all the parts required to convert the skimpy 8mm nut on our XL to a 17mm nut to hold the wheels. 17mm Hex Hub Nut (4 pieces) - AX31230 Hex Hub Set 17mm Yeti XL (4 pieces) - AX31255 M5x6mm Set Screw (4 pieces) - AX31261 - grub screw? Pins???? Am I missing anything before I put my order down? Or there are better aftermarket options I'm not aware of. I know Traxxas hubs will work, but I'm trying to avoid any parts modifications (like drilling the Traxxas centre hub to 8mm... impossible for me). Last edited by keeleong; 01-30-2015 at 03:01 AM. Reason: added "Pin" |
01-30-2015, 02:44 AM | #2 |
| Re: Yeti XL to 17mm hex conversion
... and the hubs are on backorder... :(
01-30-2015, 03:04 AM | #3 |
I'm really getting confused now after looking at this. Do I need the shaft as well? Because the hubs come with a hole for a pin, and in the RTR, I've no idea how to mount the hub (as the RTR shaft does not have any holes). |
01-30-2015, 03:09 AM | #4 |
Rock Stacker Join Date: Dec 2014 Location: Australia
get erevo hub kits drill the back end with an 8mm drill bit most of the way through fit to xl done |
01-30-2015, 03:10 AM | #5 |
| Re: Yeti XL to 17mm hex conversion |
01-30-2015, 04:38 AM | #6 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
You didn't search well enough, there's a couple threads with the answer to your question. And yes you will need new front stubs and rear shafts. Here's the parts needed for the new wheel hex conversion for the RTR: Axial Rear Axle 10x169mm (17mm Hub) Yeti XL - AX31260 Axial Front Axle Stub 16x39mm (17mm Hub) Yeti XL - AX31259 Axial Hex Hub Set 17mm Yeti XL (2) - AX31255 |
01-30-2015, 11:07 AM | #7 |
thanks, Steve. now the list is geting longer.... |
01-30-2015, 11:53 AM | #8 |
Keep in mind that Axial generally sells parts in a package of two so you will only need one each of the first two items I listed and two of the last item.
02-18-2015, 10:00 AM | #9 |
Rock Stacker Join Date: Jan 2015 Location: jal
Are the stock rims 17mm hex? Or are all doing this to get new rims and tires? Also what wheel nuts do you suggest? I stripped the wrench that came with the rtr version so I'm wanting to upgrade cause I hate the damn wheel nuts lol.
02-18-2015, 10:14 AM | #10 | |
Newbie Join Date: Feb 2015 Location: USA
| Re: Yeti XL to 17mm hex conversion Quote:
Yes...the stock YETI XL rim accepts a 17mm hex. | |
02-18-2015, 11:20 AM | #11 |
Wait and upgrade to these new Axial parts when they become available. |
02-18-2015, 12:35 PM | #12 |
04-25-2016, 10:15 AM | #13 |
Newbie Join Date: Apr 2016 Location: ypsilanti
Could you use the stock rtr stubs and just cut off the treaded part?
04-25-2016, 04:42 PM | #14 |
Pebble Pounder Join Date: May 2015 Location: Baton Rouge
I would go with the axial conversion but if you are impatient... Hot Racing has a 17mm conversion set for the RTR. |
04-25-2016, 04:44 PM | #15 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
| Re: Yeti XL to 17mm hex conversion This is the kit I used on my Kit version. I had to buy RTR axle shafts and stub shafts to make it compatible tho.. This was before HR had released the kit for kit versions.. Strong as hell tho. Worthwhile upgrade.
04-25-2016, 04:57 PM | #16 | |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Not a good idea at all unless you have access to machining equipment. | |
Yeti XL to 17mm hex conversion - Similar Threads | ||||
hex adapters for 17mm hex. | littlemel | Formula Offroad | 1 | 10-01-2013 11:31 AM |
wheels? need a 17mm hex. | newblnc | Superclass Crawlers | 2 | 05-29-2012 06:39 AM |
17mm Hex with 8mm ID? | run2jeepn | General Crawlers | 3 | 09-14-2009 05:11 PM |
