Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: RTR ESC Note of mention
Old 03-06-2015, 07:16 AM   #1
Default RTR ESC Note of mention
I had a weird issue where I thought that my ESC was not "bound" because the ESC was lit up and beeping but nothing was happening, I messed with it for two evenings and stumbled across the cause. If you look at the wires leaving the ESC to the receiver tray they are attached by a plug and are not soldered in the ESC internally. Basically what I have found is the plug basically just "rests" on the pins, it did not "snap" into anything and it is a VERY loose connection and comes off VERY easy. I am not sure of a fix or what Axial will say but I wanted to mention it here if anyone was having any radio woes to check that out before flipping out and getting frustrated. When I get a response from Axial I will post the response. Hope this helps.
rob4607 is offline   Reply With Quote
Old 03-06-2015, 05:05 PM   #2
Default Re: RTR ESC Note of mention
I too have found the plug just doesn't really engage to the pins very well. This is the plug you remove to connect a Castle Link. I ended up tweeking one of the outside pins on the ESC just a little bit to make some friction. Feels a lot better now. Also take all the slack out of that cable by stuffing it into the receiver box better. This will keep it from flop'n around.
Money Pit is offline   Reply With Quote
RTR ESC Note of mention - Similar Threads
Note To Self LR3 Chit Chat 6 10-08-2011 06:08 PM
Note to self: LumTheMad Chit Chat 16 01-09-2011 08:44 PM
note to self(and others) littleWOJIN Chit Chat 10 08-18-2008 08:27 PM
Note to self..... FrankyRizzo Chit Chat 2 07-14-2006 12:50 PM
Another Magazine Mention! jason General Crawlers 2 12-17-2004 03:00 PM
