04-01-2015, 09:28 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| plastic pivot balls
Got my kit today and was reading the manual and learning. Did a Google and Flea Bay search and did not find but 2 or 3 steel ones. Anyone come up with a solution for steel pivot balls?
04-01-2015, 09:34 PM | #2 |
Newbie Join Date: Feb 2015 Location: Las Vegas
| Re: plastic pivot balls
Go get some RPM end link.. and traxxas sells the end balls with their small end links.. Rob the pivot balls from one kit.. and put them together with the RPM kit.. and POOOF!.. I have done this for most of my XL and the longer RPM end links and traxxas pivot balls give me a ton of adjustment and smooth operation.
04-01-2015, 09:41 PM | #3 |
Wich ones? I measured the steel pivot balls from my Slash 4X4 and they are smaller than the YXL ones. I searched the exploded views on traxxas site and they don't list the actual ball size. I even tried checking part numbers for end links on A-Main but they only list what the rod end fits not actual ball size.
04-01-2015, 09:59 PM | #4 |
Quarry Creeper Join Date: Feb 2015 Location: Douglasville
The steel ones from Dhawk on eBay work great. You will need three sets of 4 to replace them all.
04-01-2015, 10:13 PM | #5 |
Thanks Bob I saw the add but didn't FULLY read just glanced at it . Got em on the way.
04-01-2015, 11:19 PM | #6 |
| Re: plastic pivot balls |
04-02-2015, 03:24 AM | #7 |
Rock Crawler Join Date: Dec 2014 Location: Rhode Island
HPI 86144 are direct replacement steel hollow balls. And you can have them way faster than two weeks.
04-02-2015, 05:44 AM | #8 |
Quarry Creeper Join Date: Oct 2009 Location: northeast ohio
Will they fit in the shocks? Mine have alot of play
04-02-2015, 08:31 AM | #9 |
Yes...that size is the same on the entire truck.
04-04-2015, 08:44 PM | #10 |
I HAVE NO LUCK. The day after I order from the other side of the world I find this> New Axial Aluminum Ball 6 8x8x3mm Yeti XL 6 AX31253 | eBay |
plastic pivot balls - Similar Threads | ||||
Replacement for all the plastic hollow balls. | Fordfreak95 | Axial Yeti XL | 0 | 12-26-2014 06:56 PM |
pivot balls for losi shocks? | imbler2 | Newbie General | 4 | 03-14-2010 10:03 PM |
Pivot Bone | HadakaJime | General Crawlers | 0 | 04-14-2008 09:09 PM |
pivot bone images | JasonInAugusta | General Crawlers | 2 | 12-09-2007 10:05 AM |
pivot mounts | trapt1011 | Tamiya Clod Buster | 4 | 11-04-2004 03:00 PM |
