07-14-2015, 04:18 AM | #1 |
Newbie Join Date: Jun 2015 Location: Trondheim
| Axial Yeti XL Kit - My first kit build
Axial Yeti XL Kit My first kit build. Electronics: CC Mamba Monster 2 - 1:8 WP ESC w. 2200kv motor Hitec HS-9475SH BL Steel Gear Servo 19.4kg/0.10 Futaba R304SB receiver I didn't use the CC BEC 10A. Is it necessary/recommended to use BEC? Video: YouTube video: http://youtu.be/qheWl_F26n8 Sent from my iPhone using Tapatalk Last edited by vashan; 07-14-2015 at 04:25 AM. |
07-14-2015, 08:28 AM | #2 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Axial Yeti XL Kit - My first kit build
Castle is well known for having a crappy internal BEC. But, I think the Mamba Monster 2 has a 5 amp BEC which is "ok" and I think will be fine for driving. As long as you don't plan to "Crawl" with it, you'll be fine without an External BEC. The MM2 is capable of adjustable voltage between 5-7v, so if your servo will handle it, push up the voltage. Just keep in mind if your servo starts "browning out" you will need to add one. |
07-14-2015, 10:41 AM | #3 |
X2 on Reds comment. You may not "Need" it but for the $$ it is cheap insurance. Great job on the build and i like the colors. The receiver antenna wire goes in the small clear silicone tube to the left. won;t hurt anything but if you put in a BEC you may need that room the antenna wire took up. |
07-14-2015, 10:56 AM | #4 |
Newbie Join Date: Nov 2014
FWIW I ran my monster 2 at 6.0v with a savox 1230 with no browning
07-15-2015, 05:17 PM | #5 |
Thanks for the comments. I tried to install Castle BEC ( CC BEC 10A ) but I could not fit the Device in receiver compartment because of the size. Anybody have suggestions where I can Place it or other BEC Components which is more suitable? ( share any experience about other models of BEC Component) Product link: Castle Creations | CC BEC and CC BEC Pro I have placed the receiver antenna cable through the small hole. |
07-15-2015, 05:58 PM | #6 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
I was able to get it inside with the stock rx. It is a tight squeeze and requires a custom short harness if you are bypassing the rx and only powering up the servo with the ebec. The castle bec should fit. You will have to move the rx into the corner of the box and lay the bec on its side with the cap facing the wire exit. I wish I would have taken pics. He is in kc now, so I cannot get them. Sent from my SM-N900V using Tapatalk |
07-15-2015, 06:05 PM | #7 | |
| Re: Axial Yeti XL Kit - My first kit build Quote:
Sent from my SM-N900V using Tapatalk | |
07-18-2015, 09:45 AM | #8 |
Newbie Join Date: Jul 2015 Location: Seattle
Vashan. I could totally be wrong, but it appears from the video that you're not getting full turn movement to the right. Left seems good, but that full right turn seems limited..... ??? Congrats on the rig btw, I miss seeing my all fresh and new like yours. Last thing: what is, and where can I get, that bag thing you have over the "engine bay"? |
07-22-2015, 09:51 AM | #9 |
Hi _WonderBeard_ I will check the movement to the right. I got the cover from Dusty Motors. Its called shrouds. They have different sizes. You have to use size XL for Yeti XL. Check out Dusty Motors website: http://www.dustymotors.com Sent from my iPhone using Tapatalk Last edited by vashan; 07-22-2015 at 02:48 PM. |
07-22-2015, 09:56 AM | #10 |
I did the following upgrade today. Replaced the rear axle truss with Hot Racing aluminum rear axle truss for Sent from my iPhone using Tapatalk |
07-23-2015, 03:37 AM | #11 |
Pebble Pounder Join Date: May 2015 Location: UK
I'm running a MM2 with a Hitec 7954 at 7v and have not had brown outs.
07-23-2015, 12:35 PM | #12 |
Todays upgrade: Axial AX30835 Wraith SCX10 AX10 XR10 Aluminum Servo Horn (24T): Hot Racing vented aluminum slipper clutch plates for the Axial Yeti and Yeti XL: Optional steel center differential 68t spur gear for Axial Yeti: Sent from my iPhone using Tapatalk |
07-23-2015, 12:48 PM | #13 |
Are you running a Power Absorbing Device (PAD) with your HSB-9475-SH?
07-24-2015, 04:30 AM | #14 |
I didnt get the Hitec PAD included with the Hitec Servo.
07-24-2015, 08:39 AM | #15 |
| Re: Axial Yeti XL Kit - My first kit build I would contact Hitec about getting one. Running without it can cause issues such glitching and premature BEC failure. Most BEC don't like a voltage coming back from the servo and hitting its output with it. June 2014: Brushless Servo Service Bulletin While compatible with most radio control devices, the regenerative braking feature of the HSB-9XXX series servos may cause a problem if the device cannot accept a backflow of current. The types of devices that cannot accept this backflow are: Voltage Regulators, Power Safe Receivers and certain BEC circuits whether stand alone or integrated within an Electronic Speed Control. Check with the manufacturer or the Hitec website for a list of compatible models. If your device cannot accept a current backflow, then you must install a PAD (Power Absorbing Device - Hitec PN# 55756) as described in this manual. A PAD is included with every Hitec brushless servo. |
07-25-2015, 01:55 PM | #16 |
I have contacted the local hobby shop where I bought the servo. On the hobby shop product information page they have the same details about PAD. Sent from my iPhone using Tapatalk |
07-25-2015, 02:00 PM | #17 |
Todays Upgrade: Axial Yeti XL Carbon Fiber Steering Brace (3mm) Hot Racing's aluminum and carbon fiber steering bellcrank steering rack: Sent from my iPhone using Tapatalk |
07-28-2015, 12:54 PM | #18 |
I got the following reply from Hitec Customer Service regarding the PAD issue: You shouldn't need them when using the Castle, Tekin or Novak ESC's. Sent from my iPhone using Tapatalk |
08-06-2015, 12:49 PM | #19 |
More upgrades Hot Racing Aluminium Rear Chassis Upper Link Mount Yeti XL Hot Racing Aluminum Rear Chassis Lower Link Mount Axial Yeti XL Hot Racing Aluminum Rear Upper Links Axial Yeti XL Hot Racing Aluminum Motor Mount Plate Axial Yeti XL Hot Racing Rear Axle Aluminum Adapter Yeti XL Hot Racing Heat Sink Motor Mount Axial Yeti XL Sent from my iPhone using Tapatalk Last edited by vashan; 08-06-2015 at 01:36 PM. |
09-01-2015, 04:46 PM | #20 |
| Axial Yeti XL Kit - My first kit build Last edited by vashan; 09-01-2015 at 04:51 PM. |
Axial Yeti XL Kit - My first kit build - Similar Threads | ||||
Imthatguy's Axial Yeti KIT Build | imthatguy | Axial Yeti | 41 | 09-01-2015 04:49 AM |
1/10 Yeti Kit Build question | Bobby D | Axial Yeti | 4 | 02-17-2015 04:55 PM |
yeti kit build problem | tuba6869 | Axial Yeti | 1 | 02-08-2015 04:22 PM |
