10-26-2015, 08:18 PM | #1 |
Newbie Join Date: Oct 2015 Location: san antonio
| Beadlock wheels
Anyone know a good set?? I am so over the glue and these tires have a bit of play on the wheels and it's a %^*€<> nightmare to reglue after each run Sent from my iPhone using Tapatalk |
10-26-2015, 09:14 PM | #2 |
| Re: Beadlock wheels
RC4WD makes the Dick Cepek 40 series 3.8 beadlocks that will fit the Yeti XL. The problem for using these wheels for the Yeti XL is weight. The stock wheels weigh 3 oz each while the RC4WD Dick Cepek 40 series 3.8 beadlock wheels weigh 9.67oz. A set will add 26.67 oz (1 2/3 lb.) of rotating mass to an already straining drive train. |
10-27-2015, 05:15 AM | #3 |
Newbie Join Date: Oct 2015 Location: Reading PA
| Re: Beadlock wheels
I'm not sure of weight but the AXIAL oversized beadlock wheels look promising, seem very light too being that they are composite with 6061 beadlock ring. part numbers: AX8014 & AX8042 edit: check your LHS for these first mine has them for $36.50 a pair |
10-27-2015, 11:13 AM | #4 |
Pebble Pounder Join Date: Mar 2015
I think the Axial beadlocks a are a little too wide for the Yeti XL tires. Axial used to make a narrower 3.8 size beadlock, but it's out of production now. I believe there is a thread on here where somebody cut down the axial beadlocks to fit the Yeti XL tires.
10-28-2015, 02:04 PM | #5 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
| Re: Beadlock wheels |
10-28-2015, 07:13 PM | #6 | |
| Re: Beadlock wheels Quote:
11-02-2015, 07:36 AM | #7 |
| Re: Beadlock wheels
Anyone know an off the shelf tire and wheel that fits? I watched my buddies LOSI never have a tire issue all day while mine was blowing beads all over the place. |
11-02-2015, 12:13 PM | #8 |
Pebble Pounder Join Date: May 2015 Location: Baton Rouge
| Re: Beadlock wheels
You can try the Pro-Line, Rock Rage 3.8" mounted on F-11's. I've personally never had issues blowing beads with Pro-Line.
02-18-2016, 07:32 AM | #9 |
Rock Stacker Join Date: Mar 2010 Location: Norway
| Re: Beadlock wheels
Just found these beadlocks on ebay. Have no clue what the weight is but they sure look great 3 8 inch Beadlock 8 Spoked Wheels 2 Pcs for RC Crawler TFL C1501 04 | eBay |
02-18-2016, 07:41 AM | #10 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
02-18-2016, 07:50 AM | #11 |
| Re: Beadlock wheels
Personally I'd spend the extra $$ for the motorworx. If your going to spend $200+ on just rims then go American and RCC vendor. Those Bad Ass and light weight for what they are they are still to heavy for the YXL. I would out them on my Losi XXL without hesitation if I wanted to spend the $$. |
02-18-2016, 09:36 AM | #12 |
| Re: Beadlock wheels
FYI My narrowed PL Welds are 6.2oz. Heavier than stock but would be perfect for Pit Bulls
02-18-2016, 02:20 PM | #13 |
Pebble Pounder Join Date: Oct 2015 Location: Fremont
| Re: Beadlock wheels
Cheap 2.8 beadlocks. 17mm hex These babies are $10.50 a pair. At Nitrorcx.com. Complete with Wheel, tire and foam. Now... They are not the best. But for less than $25 a set to your door, they could be a good basher set up? http://www.nitrorcx.com/mad-mt2009-2010-cblue.html Available in green or orange also. (I am stripping the blue with oven cleaner on mine.) Pick up an extra set of wheels only for $4.00 a pair! http://www.nitrorcx.com/mad-mt2009.html They are only 6.3" tall, but that could help with traction rolling. So would the tires not having any traction. Sent from my iPhone using Tapatalk |
02-19-2016, 01:40 AM | #14 |
| Re: Beadlock wheels
Asked the ebay guy about the weight and he answered 11.6 oz (328g). Too heavy IMHO. Those Motorworx wheels looks absolute fantastic but they are pricy, especially shipped to europe with taxes and all that stuff. Guess I'll order some Axial oversize and narrow them Is there a thread here on how to do that? |
02-19-2016, 06:31 AM | #15 | |
3.8/40 series wheel narrowing Wes | |
Beadlock wheels - Similar Threads | ||||
2.2 beadlock wheels | KennethXJ | 2.2 Scale Rigs | 0 | 10-15-2012 05:11 PM |
Beadlock vs non beadlock wheels | Kocis715 | Tires and Wheels | 0 | 05-19-2012 05:16 PM |
