03-30-2016, 10:59 PM | #1 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| HOW To Drive A XL 101 Please leave any and all logical and illogical recommendations here!! some serious and on the lighter side Thanks |
03-30-2016, 11:01 PM | #2 |
| Re: HOW To Drive A XL 101
EXAMPLE: 84yoda Rock Crawler Join Date: Apr 2015 Location: Roseville, Ca Posts: 812 Default Re: Castle Creations Programming by Castle -------------------------------------------------------------------------------- I haven't touched any punch or brake in esc but did turn down brake in my radio after front diff started clicking. Waiting for it to blow up to install dhawk and hd gears. I never pin it or launch it from starts, I always take off slow and get rollin then will launch it during the roll. I also try to stay away from driving it on the street since there's no give like dirt. |
03-30-2016, 11:12 PM | #3 |
Pebble Pounder Join Date: Feb 2016 Location: Stillwater
It'd be cool too if people included punch and brake settings as well as whether they're running 4s or 6s! Sent from my iPhone using Tapatalk |
03-30-2016, 11:47 PM | #4 |
Rock Stacker Join Date: Dec 2015 Location: Canada
OK, here goes: Battery: 4S External BEC: 7.4V Brakes: 50% in ESC, 40% in radio, 20% overall Punch control: 50% Throttle curve: slightly S-shaped Brake curve: linear 0 to 100% AVC Settings AVC priority: 80% ST gain: 60% TH gain: 10% I also have the Robinson Racing slipper set up so that if you hold the rear wheels it will lift the front off the ground by maybe 3-4" When I drive I try not to hit things, if you hit things it tends to break no matter how many expensive bearings, gears and aluminum bits you have on it. Last edited by sparwood; 03-31-2016 at 12:18 AM. |
03-31-2016, 12:22 AM | #5 |
| Re: HOW To Drive A XL 101 Oho we might as well include bone head pictures !! wrecks, carnage, and senseless beatings aftermaths |
03-31-2016, 01:36 AM | #6 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: HOW To Drive A XL 101 Quote:
03-31-2016, 03:20 AM | #7 |
Newbie Join Date: Jan 2016 Location: Michigan
Robinson racing all the way down Aluminum front housing HD gears with BHB mod done Ceramics in both diffs. Dlux rear sway bar with 2nd to largest bar Mamba monster x and CC 2200kv on 4s Punch control at 40% brakes at 25% I try to never punch it from a stop, sand, asphalt, stones, just never go full throttle from a dead stop. Like posted wait until it's rolling then squeeze the trigger, I never slam it full throttle. Try to never land under throttle and if it's going to land nose down I'll put the brakes on so it'll just land on its lid. I'd rather replace the plastic than blow a bearing. My RR slipper still slips pretty good if you nail it from a stop or the tires get hung up climbing trees. I've blown two diff bearings in about 6 total packs though so not sure this is good info lol |
HOW To Drive A XL 101 - Similar Threads | ||||
Lr 101 | JN80 | 1.9 Scale Rigs | 2 | 11-05-2014 02:09 PM |
AX10 MIP C Drive dig drive shafts in stock! | RPP Hobby | RPP Hobby | 1 | 12-03-2009 10:50 PM |
Need help w/ ESC 101.. | ScaleHobbies | Electronics | 4 | 02-27-2005 06:33 PM |
