![]() | #1 |
Newbie Join Date: Aug 2016 Location: New Zealand
Hi all I have just bought the yeti XL kit. Was Pretty impressed with the size of it. So I hooked up my ZTW motor /Esc and gave its first run and proceed to strip the wheel ha ha newbie mistake not checking my wheel nuts ![]() ![]() I am making up a list of up grade parts The alloy steering rack The proline f11 wheels and some shockwave 3.8 tyres. Rpm front arms Then replace parts as I need them ( or break them ) Looking forward to gathering as much information and hopefully sharing my up grades with the XL Cheers ![]() |
![]() | #2 |
Pebble Pounder Join Date: Jun 2016 Location: Keizer
I stripped a wheel on day one too. I have found it beneficial to add a second 17mm nut to each wheel to act as a lock nut. Also HD gears are a must-look at the BHB HD Gear mod thread on hear-lots of good info
![]() | #3 |
Rock Stacker Join Date: Feb 2016 Location: Kennebunkport
I used a $0.03 set socket head screw and it has held up great....
![]() | #4 |
That's why I am going to give the proline wheels a shot. I ran 3 packs of 6s through the proline truggy wheels and didn't have a problem with the wheels coming loose ![]() |
![]() | #5 |
Rock Stacker Join Date: Oct 2016 Location: Detroit Lakes
Make a cover to protect the rear pinion bearings...a lot of debris gets in there....pro mod Steve came up with an easy solution...here is what I did to mine ![]() ![]() Sent from my iPad using Tapatalk Pro |
![]() | #6 |
Yeah its defiantly on my to do list when my new GPM drive shaft turns up plus will be doing the 3 bearing mod to as when I pulled the rear axle apart one of the bearings was very lumpy ![]() |
![]() | #7 |
Rock Stacker Join Date: Oct 2016 Location: Staten Island
![]() | #8 |
| ![]() ![]() This is the the item I got my cover from Sent from my iPad using Tapatalk Pro |
![]() | #9 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
I use caplugs I order off ebay part# 15X you have to trim to fit depth wise. I order used ones when I can as they are perfect just not the new price.
