08-19-2016, 10:44 AM | #1 |
Newbie Join Date: Jul 2016 Location: England, UK
| Upgrade advice
Is it worth buying sway bars for both front and rear?* Also will these be a direct fit? Been told body panels will hit the tyres on a turn? -*Pro Line PL1184-13 - ProLine Trencher 3.8 Tyres Mounted on Black F-11 Offset 17mm Hex Wheels I am thinking of buying these sway bars for the rear. -*Axial H-AX31252 - Axial Yeti XL Rear Sway Bar Set (So Anyone using lights on there Yeti XL? If so what ones please. |
08-19-2016, 10:58 AM | #2 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Re: Upgrade advice
Wheels should be ok. I only use a rear sway bar never felt I needed a front.
08-19-2016, 11:08 AM | #3 |
| Re: Upgrade advice
I want to get a big order in. I want to upgrade my wheels/tyres, new body panels, lights, sway bar etc. I want help on what upgrades to do so I can buy all the parts at once. What wheels/tyres do you use on your Yeti XL? |
08-19-2016, 11:54 AM | #4 |
| Re: Upgrade advice |
08-19-2016, 12:00 PM | #5 | |
| Re: Upgrade advice Quote: I am preferably looking for mounted tyres/wheels. The prolines I linked in this thread seem to be the best pre-mounted tyres right? | |
08-19-2016, 12:07 PM | #6 |
| Re: Upgrade advice
Are these any better? - Pro Line PL1178-11 - ProLine Badlands 3.8 Mounted on Black Desparado 1/2 Inch Offset Wheels - 17 |
08-19-2016, 01:10 PM | #7 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: Upgrade advice
The Badlands are way smaller that the stock tires.. But they would be great for a dirt track, parking lot or smooth surfaces... unreal traction!!!!!
08-19-2016, 01:52 PM | #9 | |
Not sure what to do then.. I want tyres/wheels same size as the stock RTR Axial Yeti XL with thicker tread etc. | |
08-19-2016, 02:27 PM | #10 |
Newbie Join Date: Aug 2016 Location: New Zealand
| Re: Upgrade advice
I have installed a front sway bar from my losi truggy and I like the way it keeps the yeti nice and level especially when coming off the power when turning. Also had a play with running truggy wheels running 6s and its a lot of fun drifting so that's why I am going to try the proline f11 wheels/ shockwave tyres combo, plus with the proline truggy wheels I had no problem with the wheel nuts coming loose but you do have an issue with ground clearance
08-19-2016, 03:26 PM | #11 |
| Re: Upgrade advice
They don't look that much smaller unless this guy in this video has done something to the car to make it higher? https://www.youtube.com/watch?v=e-bb5boQcYU |
08-19-2016, 04:42 PM | #12 | |
I mean his Yeti looks high because of the tires. It really boils down to where you will be running terrain wise and what you are doing with it. There are a bunch of combos and none that have been posted other than looks are a bad choice. Last edited by THX_138; 09-10-2016 at 09:44 PM. | |
08-19-2016, 05:19 PM | #13 | |
| Re: Upgrade advice
I'm that guy lol... BL 5 7/8" Stock 7 3/8"... Quote:
08-21-2016, 10:43 PM | #14 |
Pebble Pounder Join Date: Feb 2016 Location: Stillwater
| Re: Upgrade advice
I ran the HR sway bar but had issues with it pulling out of the mounting holes on the front bulkhead... It functioned somewhat without being fully secured but after a concrete light foundation jumped out of nowhere and I ran into it shoving the HR sway bar mounts through the plastic diff cover. I've removed it until I decide how I want to mount it where it won't pull loose from those tiny plastic brackets or until I upgrade to a metal bulkhead. It worked really well and was a lot more enjoyable of a drive when it was installed though! Sent from my iPhone using Tapatalk |
Upgrade advice - Similar Threads | ||||
New Wraith, Need upgrade advice | OsiViper | Axial Wraith | 19 | 02-10-2014 12:38 PM |
Upgrade advice | idk | General Scale Talk | 2 | 08-16-2013 02:44 PM |
Shock upgrade advice please. | Blackvelvet | General Scale Talk | 2 | 02-07-2012 07:17 PM |
Need upgrade advice, New to Axial's | WestTxRc | Axial SCX-10 | 5 | 11-08-2011 05:01 AM |
advice on next upgrade | gobucks | Tamiya TLT Crawlers | 13 | 12-07-2007 03:35 PM |
