Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Robinson racing spur
Old 11-18-2017, 07:00 PM   #1
Default Robinson racing spur
Just got my 64t spur from Robinson racing and when I apply throttle my tires dont spin at all. Its on a stabd as well. I did read the thread about it but don't see anything about how long the break in process takes.
Sent from my LG-H918 using Tapatalk
talento is offline   Reply With Quote
Old 11-20-2017, 05:13 PM   #2
Default Re: Robinson racing spur
Break in is quick, do some hard full throttle pulls and let it slip a little then tighten the nut. As it breaks in, you can tighten it more. Keep the nut tight then back off a hair at a time till you like it.
84yoda is offline   Reply With Quote
Robinson racing spur - Similar Threads
Robinson Racing steel slipper spur rubbing t3yf5g Axial Wraith 12 08-04-2012 08:37 PM
Robinson Racing spur gear diameter racerfred General Crawlers 3 01-27-2012 12:42 PM
Robinson Racing Super Spur ????? casepuller Axial AX-10 Scorpion 8 01-22-2010 08:10 PM
Robinson Racing Steel Spur. Thorsteenster General Crawlers 7 08-24-2007 01:40 PM
