02-17-2017, 12:27 PM | #1 |
Pebble Pounder Join Date: Feb 2017 Location: SoCal
| Rear Body Mount
I'm looking for some suggestions: after running into some serious mud I took the YXL apart to clean it, and I managed to lose one of the two little plastic clips that screw on to attach the roll cage at the rear, where it hinges. I can get a new one through Axial, but it means buying AX31010 which includes half of the roll cage as well, which I really dont need. Any one have thoughts about alternative ways to attach the body at the rear? I could just use zip ties, I guess, but I'm wondering if anyone has come up with a better solution. Thanks! |
02-17-2017, 02:50 PM | #2 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: Rear Body Mount
If you look closely there are body post mounts in your cross brace of your rear cage with a hole pre drilled for the shock tower set screw. You can pretty much mount any body. Far as remounting the yeti XL body all you need to do is cut out a piece of plastic and attach it with two screws for the tire mount location and drill out two holes for the body post. Last edited by BarHarborBasher; 02-17-2017 at 02:52 PM. |
02-17-2017, 04:24 PM | #3 |
| Re: Rear Body Mount
Thanks BHB. I'm just looking to remount the existing body though, and looking to see if anyone has thought of a better version of the existing hinge-mount.
02-17-2017, 06:06 PM | #4 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Rear Body Mount
Zip tie?
02-17-2017, 08:49 PM | #5 |
| Re: Rear Body Mount
Yeah like I said I'm hoping for something better but zip ties will do the job.
Rear Body Mount - Similar Threads | ||||
Rear Body Mount | Chip73 | Axial Yeti XL | 5 | 01-01-2016 07:47 AM |
how to mount the rear of an HPI '73 bronco body? | ussprinceton2004 | Axial SCX-10 | 4 | 09-11-2015 05:56 PM |
hinge as a rear body mount | stanmondz | Paint and Body | 0 | 03-21-2013 09:14 PM |
Jeep Wrangler Rear body mount | Tedro | Tamiya XC/CC01 | 4 | 10-02-2010 05:34 AM |
