03-01-2017, 05:08 PM | #1 |
Newbie Join Date: Feb 2017 Location: sw bristol....uk
| 15x18mm shims.....
been tyring to do the 3rd bearing mod but theres too much play without the stock plastic spacer so tried to find sum shims but cant find any in the uk....or anywere what will ship to me for sensible £££ ...long shot...but anyone got any spares |
03-02-2017, 01:17 AM | #2 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: 15x18mm shims..... |
03-02-2017, 11:22 PM | #3 |
| Re: 15x18mm shims..... Be careful, though, they are wider than the original shims, you should never use them in direct contact with the bearings, either use them together with the original shims (kind of a sandwich), or narrows them with a nail scissors. If you use them as is, you will seize the bearings. Read the thread carefully.
15x18mm shims..... - Similar Threads | ||||
Shims | tphjill | Axial Yeti XL | 14 | 01-12-2017 09:51 AM |
SHIMS.....where can I get some? | chipgibbs | General Crawlers | 5 | 12-18-2015 08:55 PM |
shims? | aircooled67 | Tamiya Txt-1 and Juggernaut | 1 | 03-26-2010 03:03 PM |
shims | mesooners | Team Losi Comp Crawler | 10 | 09-11-2009 10:14 PM |
shims | mesooners | Team Losi Comp Crawler | 11 | 08-29-2009 08:54 PM |
