03-07-2017, 12:12 PM | #1 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Center Differential Yeti XL
Well as some of may remember a project that I started a little while back . Project XL-T TWIN 2200 Dragster. Till I round up enough cash for the 2nd ESC & 6S 5000 batteries, aluminum diff cups/GPM internals /GRP tires/ HD CVD conversion I'm gonna have to settle for one motor . This is the Banshee XL Thanks again Tphjill for the beautiful HR bulkhead/front & rear track bars !! I made the center diff motor mount out of scrap aluminum with basic hand tools. Some of the parts in this build or generously donated by Tphjill !! I really appreciate and admire the generosity and that's why I'm excited for you guys to see what I have to give back to the community I was able to re-use the existing transmission holes and add one in the battery trays for tying everything together. I made this out of some scrap pieces of lexan as a debris deflector. Got to have a Basher Bar to lock the front down !! Awesome mod !!! Perfect perch for shock tower supports My ESC cooling fan mod When you have so many builds going on that a $9 part doesn't make the budget you learn to improvise. This is a worn-out set of front output that were egged out. I simply cut them down the length and grind additional debt and use them as rear output. For the front output I decided to use an MIP T-Maxx heavy duty output. Instead of using a pin I decided to make dimpled set screws. I found these 20 millimeter Hub extenders and instead of using the set screw I decided to use a 25 millimeter screw that I ground down the head to help support the outer portion of the Hub So the big question is shouldn't be a drag truck a pit basher or a trophy truck your guess is as good as mine cuz they all seem perfect..... Last edited by BarHarborBasher; 03-07-2017 at 12:18 PM. |
03-07-2017, 12:47 PM | #2 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: Center Differential Yeti XL
That blue body is killing me! Sent from my Sony Xperia Z5 |
03-07-2017, 01:00 PM | #3 |
| Re: Center Differential Yeti XL LOL Me too !!! I hate to even think about cutting it lol.. I planned on using it for the SMT 5 but.... if i decided to use it for a dragtruck ive got some hacking to do...I picked up this JC Concepts body for 15$.. I'm removing the window tint because the YXL interior/Drivers fit ! |
03-07-2017, 07:19 PM | #4 |
Pebble Pounder Join Date: Dec 2016 Location: Springville
Beautiful!!! I'm glad the parts came in handy! Thanks for the shout out! Sent from my iPhone using Tapatalk |
03-07-2017, 07:22 PM | #5 |
I'm in awe at your skill in creating these custom parts and mods. It's incredible. Sent from my iPhone using Tapatalk |
03-08-2017, 12:59 AM | #6 |
| Re: Center Differential Yeti XL |
03-08-2017, 07:31 AM | #7 |
Awesome work as usual BHB. Look forward to seeing this with the Chevy body. How about a $15 Thunder Tiger KRock CD? Looks like it may work with an adapter plate and some DS work. |
03-08-2017, 12:21 PM | #8 |
| Re: Center Differential Yeti XL We'll never know till we try it out I chose the XL spur because of its radius and it's surprisingly HARD !! . I figured sense I've got mainly 2200kv motors kicking around I've got to do my best to make the ratio semi- reasonable... Also I know what the c/d internals can handle and everything is interchangeable. You could also run a horizontal support from the back of the cage to the front of the Tower and connect top of the center diff to the support for Extra Strength... let me know if you need anything Mike. I can't wait to see what this thing's going to be like... Kraton Killer
03-09-2017, 01:33 PM | #9 |
The RC4WD beadlocks showed up and I can say they are quite impressive. They are robust with a tight-fitting hex and a huge offset. One coolest hidden secrets to me about these wheels is the back of the wheel is flat and has six circles that indicate the Lugnut location for the hubcap. I'm 99% positive that those circles will line up perfectly with the RC 4 wheel drive hub adapter for future modifications. Explain to my wife that I couldn't remove the tires from the wheels because I used Bob Smith's industrial Super Glue which is sort of true. So naturally I have to order a set of Mickey Thompson scalar tires to complete the bomber XL build. The Banshee XL in beast mode I just can't decide..... Monster truck body or Dragster.. And so I've been looking at chopping and modifying the cage and possibly vacuum forming a body because that's something I've always wanted to try. Last edited by BarHarborBasher; 03-09-2017 at 01:39 PM. |
03-09-2017, 01:49 PM | #10 |
Blue body, blue body!!!!!! Sent from my Sony Xperia Z5 |
04-09-2018, 04:54 PM | #11 |
Quarry Creeper Join Date: May 2010 Location: Los Angeles
oooof. Damnit photobucket why did you have to change your policy on 3rd party hosting! So much of BHB/Hemistorms info is lost! Even if I click on the photos and refresh as a photobucket member no go. :( |
04-09-2018, 10:30 PM | #12 | |
| Re: Center Differential Yeti XL Quote:
Photobucket Embedded Image Fix | |
04-12-2018, 01:59 PM | #13 |
Newbie Join Date: Aug 2016 Location: New Zealand
Has anyone besides BHB done this CD conversion ? . Would like to here how they have done the conversion and what they think about it. Cheers |
04-12-2018, 11:11 PM | #14 | |
04-13-2018, 07:39 PM | #15 | |
| Re: Center Differential Yeti XL Quote: this is going to help immensely. Along with BHB of course | |
Center Differential Yeti XL - Similar Threads | ||||
RC Crawler Center Differential? | Ahod39 | Newbie General | 10 | 11-02-2016 12:20 AM |
Buggy center differential > Manual clutch ? | klampykixx | General Crawlers | 14 | 05-19-2014 06:19 PM |
