03-21-2017, 05:11 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
| What am I missing?
So close! Finally got my motor and electronics ready for install. I put my wheels on and they rotate in opposite direction. If I roll forward on front wheels rear wheels rotate backwards . If I roll backwards on front wheels,rear wheels rotate forward. Same with rolling on back wheels. Double checked front and rear gear boxes and they are installed properly, they both rotate smooth as butter independently. What am I missing? |
03-21-2017, 05:24 PM | #2 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: What am I missing?
You put the one of diff's crown on the wrong side. Most probably in the back, the picture in the manual is from below. Rotate the diff 180 degrees and you'll be fine Sent from my Sony Xperia Z5 |
03-21-2017, 05:33 PM | #3 |
What do you mean by crown? Unfortunately your picture did not come through. I just finished disassembling both front and rear gear boxes, they are built and installed exactly as the manual shows. I just put everything back together, but if needed I will disassemble and take pictures. |
03-21-2017, 05:41 PM | #4 |
The crown is that thing that pinion rotate on (AX31053). And those are differentials, not gear boxes. Trust me, you install one of the diffs the wrong way Sent from my Sony Xperia Z5 |
03-21-2017, 05:44 PM | #5 |
Quarry Creeper Join Date: Apr 2016 Location: Cape cod
One of your diffs is in backwards. They should be opposite of one another. I think the front ring gear should be on the right and the rear on the left but I could be wrong and it's opposite.
03-21-2017, 05:47 PM | #6 | |
| Re: What am I missing? Quote:
Cheez, check out the manual again, page 12 and 14 Last edited by Tzicul; 03-21-2017 at 05:49 PM. | |
03-21-2017, 05:48 PM | #7 |
Newbie Join Date: Dec 2016 Location: British Columbia
I had the same thing happen. The differential in the rear was backwards. With the truck on its wheels facing away from you the rear ring gear should be to the right of the pinion. In my excitement of building the truck mine was backwards. If the rear is in the correct spot than likely your front is incorrect. |
03-21-2017, 05:51 PM | #8 |
Here is one with both diffs in the wrong way, stupid me https://www.youtube.com/watch?v=3o8ZXpJmIzg |
03-21-2017, 05:52 PM | #9 |
Thanks guys, I'm going to disassemble and start from scratch. But I just did that and my build looks like step 3 on page 12and step7 on page 14. I also followed fast Eddie's YXL build on YouTube.
03-21-2017, 05:57 PM | #10 |
Start from the back, that's where people usually made the mistake, The ring has to be on the right hand side when you look from behind.
03-21-2017, 06:02 PM | #11 |
Oh, and the car has to stay on it's wheels. Maybe you assembled the car upside down! Which mean the right is left and viceversa
03-21-2017, 06:12 PM | #12 | |
Thanks guys for all the help I'm sure I'll get this squared away. | |
03-21-2017, 06:30 PM | #13 | |
http://www.rccrawler.com/forum/attac...1&d=1490142500 http://www.rccrawler.com/forum/attac...1&d=1490142500 Last edited by Cheez; 03-21-2017 at 06:32 PM. Reason: Add text | |
03-21-2017, 06:38 PM | #14 | |
http://www.rccrawler.com/forum/attac...1&d=1490143062 | |
03-21-2017, 06:41 PM | #15 |
Yes, it is!!! There you go! Sent from my Sony Xperia Z5 |
03-21-2017, 06:43 PM | #16 |
Actually I beleive you installed the enire axel wrong. The lower link isn't suppose to be below the axe? Sent from my Sony Xperia Z5 Last edited by Tzicul; 03-22-2017 at 12:54 AM. |
03-21-2017, 06:45 PM | #17 |
Thanks man!, Sometimes it's two steps forward and one step back. Fast Eddies YT build is awesome but sometimes a little confusing. |
03-21-2017, 06:47 PM | #18 |
And AX31026/2 above the axle Sent from my Sony Xperia Z5 |
03-21-2017, 06:51 PM | #19 |
Sure! Anytime Sent from my Sony Xperia Z5 |
03-21-2017, 06:52 PM | #20 |
So, after all, you were right, the diff was in it's place. The entire axle wasn't! LOL Now let me sleep, it's freaking 3 AM and I'm working tomorrow ))) Sent from my Sony Xperia Z5 Last edited by Tzicul; 03-21-2017 at 06:54 PM. |
What am I missing? - Similar Threads | ||||
am i missing anything/ | slashinbashin | Axial XR10 | 13 | 02-05-2012 04:12 PM |
What am I missing? | Waner | Chit Chat | 5 | 01-14-2012 07:08 PM |
1.9 am i missing something? | obijuan | Newbie General | 1 | 01-02-2007 09:49 PM |
