04-27-2017, 11:07 AM | #1 |
Newbie Join Date: May 2010 Location: Dayton
| XL Steering Links, Camber link Options
Picked up a used Yeti XL couple weeks ago and went thru it and am very satisfied with its performance except for the cheesy stock steering, Anyhow going to pick up a hot racing or gpm complete steering rack and pivots but would like to know what everyone is using for better steeing links, camber link and servo link, building your own ? Using pre made turn buckles ? If so please post some part numbers !! Thanks guys 😉
04-27-2017, 01:44 PM | #2 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Re: XL Steering Links, Camber link Options Axial Racing - Yeti look here |
04-28-2017, 02:43 AM | #4 |
Rock Crawler Join Date: Mar 2012 Location: UK
| Re: XL Steering Links, Camber link Options |
04-28-2017, 01:30 PM | #5 |
04-28-2017, 02:04 PM | #6 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
Wow, I didn't know they made front links. Great option too. I got there rear links and they are beefy. I think they are aluminum right.
04-28-2017, 02:34 PM | #7 |
Yep aluminium, the camber links are the same as there upper rear links and the steering links are aluminium rod with m4 studs and Revo Rod ends
04-28-2017, 05:11 PM | #8 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
I used VP Ti links and revo rod ends. From XL aftermarket thread: For anyone who wants to run vanquish titanium links for front steering/turnbuckles, here is what I used. Vanquish 55mm link + 5347 rod ends (70mm overall) for servo horn to servo saver. Vanquish 85mm + 5347 rod ends (100mm overall) but turn out both sides to roughly 103mm (use stock plastic to get it exact length). Vanquish 90mm + 5347 rod end (105mm overall) but turn out both ends to roughly 108mm (use stock plastic to get it exact length). So from vanquish you will need, one 55mm, two 85mm and two 90mm titanium links plus a bag of TRA5347 rod ends. |
XL Steering Links, Camber link Options - Similar Threads | ||||
Best steering link options? | Motorider | Axial SCX10 II | 9 | 11-17-2016 05:32 PM |
