Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Transmission maintanance
Old 06-06-2017, 03:02 PM   #1
Default Transmission maintanance
So my Yeti has been clicking some on hard breaking and I through it was coming from the trasmission. I bought my Y used off RCG and it was run hard.
So I opened it up, for the first time and it was a total mess. Dirt all in the greese
I am impressed it ran as well as it did.
I cleaned it and used marine greese to put it back together and installed fast Eddie bearings.
Now I get way too much drag and a high pitch noise. Only ran it for 2-3 mins light throttle.
So I am going to tear it down again and check the gears.
It spins nice without a motor attached and doesn't make any real noise.
So it might be my mesh..... or something else.
Adidas4275 is offline   Reply With Quote
Old 06-06-2017, 03:06 PM   #2
Default Re: Transmission maintanance
Realized Tapatalk works.
Old 06-06-2017, 07:49 PM   #3
Don't over tighten the screws on the transmission case around the slipper shaft assembly. If they're snugged all the way down it causes it to have a rotational bind. I recommend snuggling all of the screws down fingertight first and then lightly tightening each screw down while spinning the slipper shaft with your finger to make sure that the mesh sounds good.. you should be pretty good after that.
BarHarborBasher is offline   Reply With Quote
Transmission maintanance - Similar Threads
Carbon Fiber Transmission Covers for VP XR10 Transmission Housing. Tomy Axles, Trannys, T-case 4 01-20-2013 07:48 AM
Axizl Transmission VS Wheely King Transmission Tonelock HPI Wheely King 13 09-03-2008 12:39 PM
