Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Tire foam inserts
Old 08-10-2017, 06:21 PM   #1
Default Tire foam inserts
Hello, I have an Axial Yeti XL kit running 6s.
I'm awaiting the arrival of my tire / wheels. I went with the dick cepek 40 series and Mickey Thompson Baja MTZ 40 series 3.8 inch.
Does anyone have this set up? And what tire foams do you use? I wanted to use crawler innovations deuces wild but it might not be big enough to fill that height tire
The Punisher is offline   Reply With Quote
Old 08-14-2017, 07:35 AM   #2
Default Re: Tire foam inserts
My yeti is on Mickey Thompson Baja MTZ 40 series 3.8 inch, I'm using foam which were sold with tires and they are rather soft - perfect for crawling.
But my yeti is heavy - 8,4 kg (18,5 lbs)
here is my last video:
https://youtu.be/xiRFavDQt34
Volgan is offline   Reply With Quote
Tire foam inserts - Similar Threads
Foam inserts 2.2 reden Newbie General 3 11-24-2010 07:08 AM
AX 10 foam inserts takeit69 Newbie General 5 10-25-2008 08:30 AM
which memory foam inserts? NeXt559 Tires and Wheels 9 06-27-2008 06:22 PM
** NEW ** Memory Foam Inserts RPP Hobby RPP Hobby 7 11-05-2007 11:32 PM
