04-02-2018, 10:58 AM | #1 |
Newbie Join Date: Apr 2018 Location: US
| Bearing upgrade
Looking for info for a durable bearing kit that will not fail as fast the factory for my yetti xl. The factory bearing set lasted 7 runs, new. Running 6s in it. I've thought about ceramic but don't want to dish out that kind of money if they are only going to last for 10 runs or less. Btw it was the front transfer case bearing that went out. Thankfully there was no damage to the case. Sent from my SM-G930V using Tapatalk |
04-02-2018, 11:21 AM | #2 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: Bearing upgrade
It's a known fact in this community that you are not supposed to run it with factory bearings not even for one run. They are absolutely horrible! Most guys from US are using Eddie's bearings set
04-14-2018, 09:08 PM | #3 |
| Re: Bearing upgrade
Ive had extremely bad luck with factory parts on 6s no matter what bearings i use fast eddies dont last much longer than stock but with aluminum front diff and vanquish rear axle the eddies seem to be holding up just fine in my opinion what the bearings are going in to matters more than the brand
Bearing upgrade - Similar Threads | ||||
Derwood Designs bearing upgrade | Sr.Irie | Vaterra Twin Hammers | 10 | 02-11-2014 12:14 PM |
VP Bearing upgrade kit? | JustinThyme | Newbie General | 3 | 12-21-2010 07:33 AM |
XR10 Bearing Upgrade - 5x10 Flanged to Replace Puny 5x8s | LincolnBlack | Axial XR10 | 12 | 10-07-2010 07:11 PM |
