10-07-2014, 09:06 PM | #1 |
ULTRA CUSTOM FABRICATION Join Date: Oct 2012 Location: 801
| The UCFab Yeti
Hey All! I got my Yeti a couple weeks ago, but I wanted to get some real drive time on it before starting a thread. I start by saying that every time I drive this car I get a headache.......from smiling so much!! I have driven 20+ 4000mah packs through it. I have only had one failure so far just a broken hub carrier, which was totally my fault. I have to say VERY good job Axial!!!! With that said, I have done a few upgrades as needed. First thing to go on the car was some UCFab 7075 trailing arms, followed by titanium upper links and new front suspension links. Next, an obvious "must have" to go on the car was a set of Ottsix Voodoo U4 tires (silvers) with CI double duce 6.0 foams (also a must have IMHO). Next on the list was to address the steering, which wasn't too bad at first, but the servo saver spring seemed to get really soft after some hard driving. I machined a 7075 spacer to put in its place, which did the trick. After that I installed a Hitec 7954 and a CC bec. I rebuilt the shocks with some 30wt oil. IMO it made the car handle much better. I found that after the first couple of packs of HARD driving the body was falling off. I really like the look of the yeti front end so to fix the issue I decided to fuse it to some flat side panels. I used 0.60 lexan to avoid having to rebuild them all the time. Here's some pics of how it sits now Last edited by Wheels7; 10-07-2014 at 09:30 PM. |
10-07-2014, 09:24 PM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: *
| Re: The UCFab Yeti
Nice work Kyle!!! Those trailing arms are legit!!! Other than swapping out your servo and the spacer you made (I want one) what other steering upgrade did you do??? Sent from my iPhone using Tapatalk |
10-07-2014, 09:26 PM | #3 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
| Re: The UCFab Yeti
Looks great, how do you like the tires.
10-07-2014, 09:37 PM | #4 | |
| Re: The UCFab Yeti Quote:
As far as the tires. The Yeti and Ottsix Voodoo U4's are a match made in heaven!!! | |
10-07-2014, 11:50 PM | #5 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
| Re: The UCFab Yeti
Great work on the body, I saw those panel screw holes when I swapped mine. What outers are you running with those foams?
10-08-2014, 05:20 AM | #6 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: The UCFab Yeti
I was able to see your old U4 straight axle truck chassis - those links. Please say we can get them for the Yeti soon...please?
10-08-2014, 07:00 AM | #7 | |
I really, really, really need to get my hands on some. | |
10-08-2014, 12:15 PM | #8 |
| Re: The UCFab Yeti Thanks chris !! I'm running med rear and soft front. Seems to be a great setup for all types of driving. That setup came straight off my ultra car which was setup more crawling.
10-08-2014, 06:49 PM | #9 | |
Thank you for you patience. I will contact every body on the preorder list as soon as I have a solid date of arrival. | |
10-08-2014, 06:58 PM | #10 |
| Re: The UCFab Yeti
On the last outing I took a big tumble and broke the rear housing @ the link mounts. I knew exactly what needed to be done. I have been running one off Dlux trusses on my ultra car for a while now with zero axle housing failures. This is what I like to call the UCFab edition Dlux truss. 1/8" Black G10 with the delrin stiffener on the long side BOOM!!!! |
10-08-2014, 07:09 PM | #11 |
Wow I have the normal CF DLux brace, those there are super beefy. Now I want to upgrade again!
11-01-2014, 07:50 PM | #12 |
| Re: The UCFab Yeti |
11-01-2014, 07:59 PM | #13 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Re: The UCFab Yeti
Very clean work . nice job
11-02-2014, 01:03 PM | #14 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
| Re: The UCFab Yeti
So do you have an info on the beefy rear axle truss, will D-Lux be making it or was it just a one off production? I like the new Dare body the lines on it are great but the 3 front head lights look out of place but still a great build! |
12-20-2014, 09:36 AM | #15 |
12-20-2014, 12:29 PM | #16 |
| Re: The UCFab Yeti
I gotta agree, the yeti body looks a lot better! |
12-20-2014, 05:51 PM | #17 |
| Re: The UCFab Yeti
Same here..this Yeti inspired me to cut up a brand new Yeti!! Thx wheels
02-12-2015, 07:06 PM | #18 |
02-12-2015, 09:30 PM | #19 |
Quarry Creeper Join Date: Jan 2011 Location: Michigan
| Re: The UCFab Yeti
Well...what's not to like? The rear end of that honey has some real "honky tonk badonka donk" 😍
05-16-2015, 03:20 PM | #20 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Re: The UCFab Yeti
Which upper links are you running? I still have the stock upper links, and they're too short to use with the Dlux Truss.
The UCFab Yeti - Similar Threads | ||||
Another UCFab Creation | morpheus_tn | 2.2 Scale Rigs | 1 | 07-14-2014 12:20 PM |
