10-29-2014, 09:19 AM | #1 |
| Yeti knuckles, weights and shafts
Yeti knuckles, weights and shafts I am happy to announce the release of the Dlux line of knuckles and shafts for the Axial Yeti! For those who are into comp crawling, you have probably already seen the knuckles that I make for all the popular axles (Dlux custom knuckles V2!) including the Wraith, XR10, Berg, Bully 2 and the list goes on. Now, Yeti owners are going to get a piece of the action. Benefits of these knuckles: The knuckles have the ability to convert from AX10 chubs to Wraith chubs by using optional shims. This is a knuckle and a knuckle weight all in one. Ultra-light all the way to decently heavy by using Delrin, 7075 or Brass Optional slug holes to adjust your weight even more Oversize, low /no maintenance bearings are standard. If you have had bearing issues in the past, kiss them good bye! Due to the design, these have an extreme amount of strength at the arm. No more bent or broken arms. You would be able to take these knuckles and install them on other applications. For example, the stock Yeti shafts are the same as Wraith or XR10 so you would be able to install the knuckles on many cars (Wraith, AX10, Berg, XR10 etc,.) Same goes for the OFNA version, there are many applications that they will work on including the Yeti. Since there are 2 different versions that I am offering the Yeti owners, it gets a bit confusing. I will attempt to put each version in their own post to try an alleviate that. Both versions will need a large inner diameter wheel to clear the knuckle. VP OMF, CI 6 bolt, stock and most RC4wd wheels tested have cleared with room. Last edited by Erik D_lux; 10-29-2014 at 09:29 AM. |
10-29-2014, 09:19 AM | #2 |
| Re: Yeti knuckles, weights and shafts
The first version is a direct replacement for the steering knuckle. You can use the stock dog bone shafts or universals. Knuckles will come in all 3 materials, from brass to delrin to 7075. I would however suggest sticking to just the brass and 7075 for pure strength unless you have something that needs to be super lite with the Delrin. One great feature is that these knuckles will come with larger than standard bearings. 10x16 on the inside and 5x13 on the outers. This will make a major difference in bearing life! Your days of blowing bearings should be over! Knuckles will come with steering arms, no slop king pin bushings, all bearings and hardware. These are available for purchase now. You would want to buy Dlux knuckles, stub shaft type is “Wraith/XR/Yeti”, single sided arms and Yeti chubs. Last edited by Erik D_lux; 10-29-2014 at 10:07 AM. |
10-29-2014, 09:19 AM | #3 |
Now, if you have watched my products for any amount of time, you will know that I am a big fan of the OFNA style axle shafts so, of course I had to make a version fit the Yeti. This is the most confusing but really isn’t that bad. The most important thing to know is that you must have a locker or some way to attach the bigger drive cup. All parts on this setup are significantly bigger than stock. Knuckles will come in all 3 materials, from brass to delrin to 7075. I would however suggest sticking to just the brass and 7075 for pure strength unless you have something that needs to be super lite with the Delrin.
Knuckles will come with steering arms, no slop king pin bushings, all bearings and hardware. These are available for purchase now. I have this setup in their own category where you can buy individual pieces or the whole kit for a discount. You can find these in the “Wraith/XR/Yeti” or “knuckle” category. Last edited by Erik D_lux; 10-29-2014 at 10:20 AM. |
10-29-2014, 09:20 AM | #4 |
save 3
10-29-2014, 10:21 AM | #5 |
I beleive that is all the information for now. Let me know if you guys have any questions. |
10-29-2014, 03:44 PM | #6 |
Looks great Erik. Good to see you burning the midnight oil nightly |
10-30-2014, 06:44 AM | #7 |
My Mom says I "burn the candle at both ends". Sure feels like it some days. Good to see you back on Trav, seems like its been awhile. |
10-30-2014, 01:34 PM | #8 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
Quick question, I assume you kept the stock steering geometry correct? If so do you think there would be a way to offer a different top plate to run wheels that dont have a large enough inner diameter like the wheels you stated?
10-30-2014, 11:36 PM | #9 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
With the ofna set up, is the locker output 5mm?
10-31-2014, 06:08 AM | #10 | |
| Re: Yeti knuckles, weights and shafts Quote:
There is always a way to figure anything out. The real problem would be if there would be enough demand to drive a project like so. 5mm as a standard, yes. I can also do 6mm on special request | |
11-01-2014, 07:43 PM | #11 |
ULTRA CUSTOM FABRICATION Join Date: Oct 2012 Location: 801
| Re: Yeti knuckles, weights and shafts |
11-01-2014, 11:59 PM | #12 |
Quarry Creeper Join Date: Sep 2011 Location: NW
Is the VP Omf inner and VP method inner ring the same? Awesome setup, |
11-03-2014, 07:39 AM | #13 |
| Re: Yeti knuckles, weights and shafts Sorry, I dont have a set of each to measure. Maybe somebody else who does can chime in or even if somebody just has a set of one or the other can measure? |
11-04-2014, 08:54 AM | #14 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
| Re: Yeti knuckles, weights and shafts The rear inside of the OMF and Method wheels have the same profile. I don't think the parts are interchangeable but they appear to be the same profile and give you more clearance then say a standard VP SLW wheel.
11-09-2014, 09:33 AM | #15 |
another question, will the OFNA shafts come with the drive cups to use them with the Blue Monkey locker?
11-10-2014, 08:56 AM | #16 |
Yep, they come with everything shown in the picture if you buy the package. |
02-13-2015, 07:51 AM | #17 |
These are now available with the Dlux open diff outputs as an option for the OFNA version so, you can now run the OFNA setup with a locker (Blue Monkey) or open diff (Dlux). Still ZERO broken OFNA setups out there! If you want the end of all front end parts, this is what youre looking for. Last edited by Erik D_lux; 02-13-2015 at 07:57 AM. |
02-13-2015, 09:53 AM | #18 |
Quarry Creeper Join Date: Nov 2008 Location: Vacaville
I plan to use some 1inch wide SLW rims with your open dif set up. Will these rims work ? Last edited by the kil; 02-13-2015 at 10:19 AM. Reason: . |
02-13-2015, 12:26 PM | #19 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
I can tell you that a Carter Fab 1" can and VP Method wheels won't work. However, a stock Method wheel and can are good to go.
02-13-2015, 12:32 PM | #20 |
So, Im running the BM locker and MIP's in front now. Will your larger bearing knuckles work with this configuration?
Yeti knuckles, weights and shafts - Similar Threads | ||||
Yeti shock oil weights? | skybolt | Axial Yeti | 14 | 03-16-2016 06:14 PM |
VP Yeti Knuckles | zjguy721 | Axial Yeti | 12 | 09-17-2014 03:38 PM |
