12-22-2014, 10:09 AM | #1 |
Pebble Pounder Join Date: Feb 2014 Location: tucson
| Transmission cober
This may be the wrong area to ask this, but This is specific to my yeti. I notice when you folks start changing gears and what not you show pictures with out the transmission cover. Is this to show the gears and changes you made? Or do you leave the cover off and not use it anymore?
12-22-2014, 02:09 PM | #2 |
Rock Stacker Join Date: May 2013 Location: Brownsburg, IN
| Re: Transmission cober
I don't use my cover anymore because I run most of my rigs with 32p gears and don't feel there is a need for the cover. I do still use covers for anything with 48p gears though because small rocks really seem to find their way in them easier. it is all preference and if you want to protect your stuff then leave the cover on.
12-22-2014, 02:16 PM | #3 |
Thanks.
12-22-2014, 10:25 PM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Remember the other thing the spur cover does beside trying to keep dirt out is it keeps your wiring out as well if it's anywhere around the trans. Pic below is my U4RC rig & I'm only running part of the cover to keep the battery wire, which will be right in front of the trans, out of the spur. Whatever your battery but especially if your using a LIPO, shorting it out because the spur chewed through the cables is fairly sure way to having a fire. |
12-23-2014, 05:07 AM | #5 |
Quarry Creeper Join Date: Oct 2014 Location: Barre
I've been running a lot in heavy mud and snow - and I have to say that the cover does a remarkable job of keep the crap out. The rest of the truck has been trashed with muck at the end of a few packs. If it's not in the way - might be worth keeping it on if you plan on running in a complete mess |
12-23-2014, 10:36 AM | #6 |
Newbie Join Date: Jun 2014 Location: Southern AZ
I have never run gear covers on any of my trucks, from short course to crawlers. For some reason they always seemed to keep small rocks in and I had better luck with no cover. Even in the sand dunes. Sent from my iPhone using Tapatalk |
Transmission cober - Similar Threads | ||||
Carbon Fiber Transmission Covers for VP XR10 Transmission Housing. | Tomy | Axles, Trannys, T-case | 4 | 01-20-2013 07:48 AM |
Axizl Transmission VS Wheely King Transmission | Tonelock | HPI Wheely King | 13 | 09-03-2008 12:39 PM |
