01-14-2015, 08:49 AM | #1 |
Newbie Join Date: Jan 2013 Location: nashua
| New Kit Yeti what motor/ ESC????
Im Picking up my Kit yeti today after work and wondering what inexpensive motor and esc combo i should get. I want it fast but dont need a rocket ship. I was looking at the novak Crusher 4pole setup. Looks pretty good and i have had good luck with novak in the past. Any other idea for setups around that price range or lower????
01-14-2015, 10:35 AM | #2 |
Rock Stacker Join Date: Nov 2013 Location: Meridian, Idaho
| Re: New Kit Yeti what motor/ ESC????
My kit arrives on Friday and I will be installing the Viper Copperhead ESC/4500kv sensorless combo. Keep in mind, this is my first non Tekin setup. I currently have 5 race vehicles all with Tekin combos but could not justify a full race setup for a bashed/rock racer. Trust me, if the Viper sucks I'll kick it to the curb and buy the proven Tekin stuff that I normally run. I'll give a full report as soon as I get a chance to run it. Stormer Hobbies has the Viper esc/motor combo on sale right now for $109.95 |
01-14-2015, 11:14 AM | #3 |
Rock Stacker Join Date: May 2011 Location: WA
Can't go wrong with a MMP and a tekin pro4 HD....
01-14-2015, 11:24 AM | #4 |
Newbie Join Date: Jan 2015 Location: Boston
I'm going to do the MmP and P4HD, under 300 for both. The elements that the RX8 has that I won't get I don't need or won't use! Plus castle is always solid
01-14-2015, 12:24 PM | #5 |
Quarry Creeper Join Date: May 2011 Location: scituate RI
The traxxas et-3s esc is a rebadged MMP and is around 70$ on Ebay and the Holmes Hobbies BL-540 pro brushless motor
01-14-2015, 02:30 PM | #6 |
Pebble Pounder Join Date: Mar 2011 Location: Florida Gulf coast
| Re: New Kit Yeti what motor/ ESC???? |
01-14-2015, 03:23 PM | #7 | |
Rock Stacker Join Date: Jan 2010 Location: Oklahoma City
| Re: New Kit Yeti what motor/ ESC???? Quote:
I have a 5700Kv Sidewinder 3 setup I'm going to try in my Yeti at some point, and it can handle 3S too. | |
01-14-2015, 03:23 PM | #8 |
RCC Addict Join Date: Aug 2012 Location: Philippines
I have a kit coming on Monday. It is getting a MMP (rebadged et-3s flashed with official MMP firmware) and Pro4HD 3000kv to ruin on both 2 and 3 cell. |
01-14-2015, 04:35 PM | #9 |
Newbie Join Date: Jun 2014 Location: Fort McMurray, Alberta
my RTR is super slow on anything 2s, I have been reading different guys thread and 3s seems to be the way to go. the battery tray was deffinatly designed to run 3s or a high mah 2s. I ran an 8000mah 20c 2 cell and then a 5000mah 80c 2c right after and the speed just wasn't what I wanted. going to throw in a 3c see what that does. most likely stock motor and esc will end up in tool box, looking to go sensored
01-14-2015, 04:57 PM | #10 |
Quarry Creeper Join Date: Jun 2010 Location: Canberra, Australia
I've ordered the Yeti Kit, and was just going to run my old Touring Car electronics in it, until I realised the yeti comes with 32P gears that have a 5mm hole/shaft for the the pinion. 1/10 scale stuff only has a 3mm shaft. So, for a bit of schooling for me, I see a lot of people running 3000kv motors. Is that because they're running 3S. If I keep to 2S like Rabidfox said, is the 4500kv range better? I like the look of that Viper set up. Well I like the price of it! Viper VX4R.45 Copperhead-R 4500kv 550 4-pole motor combo, VIP6VSVX4R451 |
01-14-2015, 05:25 PM | #11 |
Newbie Join Date: Apr 2010 Location: Duluth
I am just going to run a take-off motor/esc from a RTR version. They are plentiful on ebay. It should be plenty of fun for me on 3S and a good time on 2S as well.
01-14-2015, 05:56 PM | #12 |
Rock Stacker Join Date: Apr 2008 Location: Houston
| Re: New Kit Yeti what motor/ ESC???? mine was faulty and replaced under warranty but other than that mine doesn't heat up, is waterproof and works great. Good value for under $120 and to get the car running.
01-14-2015, 07:54 PM | #13 | |
The one drawback I see with 3 cell is the extra weight if your car has a tendency to push or is rear heavy causing it to nose up. | |
01-14-2015, 08:55 PM | #14 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
HobbyWing sct pro and either a Tekin pro4 hd or lrp 550
01-15-2015, 06:52 PM | #15 |
| Re: New Kit Yeti what motor/ ESC???? Any thoughts on what gearing you'd be looking at with a 4500-5000 on 2S? I'm going to get the Viper combo from Amain, but not sure if the stock gearing would be right. Absolutely no idea actually...
01-15-2015, 08:41 PM | #16 |
According to the viper gearing chart the stock spur and 16 tooth pinion should be right on the money. Great down on the pinion if things get hot or gear up the pinion if things are cool but u want more top end speed. BTW...a gearing chart comes with the combo |
01-15-2015, 09:01 PM | #17 |
Thanks mate. Should have done a bit more googling. I see the chart on their website. I'll start with the stock gearing and take it easy for the first pack or two....
01-17-2015, 07:53 PM | #18 |
In doing some looking around I think the Tekin Pro4 SC 4x4 4600kv might be a good mate to the MMP using 2S.
01-22-2015, 07:16 PM | #19 |
Rock Stacker Join Date: Jan 2008 Location: Escondido
I have the crusher combo in the mail, I will let you know how they perform.
02-10-2015, 02:42 AM | #20 |
Newbie Join Date: Jan 2015 Location: Okinawa
I am ordering my Yeti Kit and am considering the MMP w/2650kv or the SV3 w/3700kv. Thoughts?
New Kit Yeti what motor/ ESC???? - Similar Threads | ||||
Yeti esc and brushless motor | Black jeep 5 | Axial Yeti | 3 | 11-24-2014 07:25 AM |
New motor-ESC for Yeti | Black n Blue | Axial Yeti | 4 | 09-21-2014 09:28 PM |
