02-22-2015, 02:13 PM | #1 |
Newbie Join Date: Jan 2015 Location: LaConner
| rear sway bar
I have installed the axial aluminum mounts and stiffer bar. What do the numbers represent, and why the set/grub screws? I thought the bar needed to rotate. Thanks in advance.
02-22-2015, 02:28 PM | #2 |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: rear sway bar
The set screws are to take the slop out, not to stop rotation.
02-22-2015, 02:47 PM | #3 |
| Re: rear sway bar
Thanks. Thats what I thought and did. Ideas on the settings/3
02-22-2015, 03:44 PM | #4 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
| Re: rear sway bar
The lower the number the softer the bar or diameter of the bar to be technical. I believe Axial has a soft, medium and hard for options.
02-22-2015, 04:19 PM | #5 |
Rock Crawler Join Date: Oct 2011 Location: Fairfield
| Re: rear sway bar
The kit comes with the soft, can't confirm that on the rtr
02-22-2015, 05:20 PM | #6 |
| Re: rear sway bar
That's what I was thinking. The firm, or thickest will fit in the medium spot too.
02-22-2015, 07:11 PM | #7 |
| Re: rear sway bar
RTR is soft also.
02-22-2015, 08:33 PM | #8 |
| Re: rear sway bar
My redneck engineered rear drive shaft fix lasted about 2 pulls of the throttle. So I will have to wait to see if stiffer springs,(hr grn rears in front, 90wt oil) and axial sway bars help handling. i have MIP driveshaft any many more parts waiting... |
rear sway bar - Similar Threads | ||||
Rear sway bar | Cchapman | Axial Yeti | 2 | 12-30-2014 11:18 PM |
Rear sway bar! | sixshooterstang | Axial Yeti XL | 3 | 11-14-2014 12:26 PM |
Rear Sway Bar | Lets Crawl | Vaterra Twin Hammers | 2 | 03-01-2013 08:39 PM |
Rear mounted sway bar. | oneeye | Vaterra Twin Hammers | 3 | 02-19-2013 06:00 AM |
