03-05-2015, 11:26 AM | #1 |
Newbie Join Date: Jun 2014 Location: flatland
| Yeti bashing setup?
So what spring rates and shock oil and front diff oil you guys using? I mostly plan to light bash and crawling fast. No skate park or bmx track stuff I still use my T3 for that. A list of parts I plan to add STRC carriers Vanquish steering knuckles Axial aluminum shock caps Vanquish ti steering links and camber links Vanquish lock outs Rear axle skid(not sure on make yet) Anything else major I need immediately? I did a search on this so if you find something just link it. Thanks. |
03-05-2015, 03:45 PM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: Michigan
| Re: Yeti bashing setup?
Ya might want to consider a front pin conversion to larger diameter, or at least a spacer to help keep the bent front pins somewhat in check. I also think rpm front arms are a cheap and wise insurance policy. And while on the front end. Pin issue it might also be a decent idea to invest in a strc front block pin holder. I found the yeti a bit of a clumsy jumper myself and if you come down heavy and awkward one side or the other you will likely either break stock carriers or hubs or bend a pin. Least ways that's how it went for me. Just a few ideas to chew on |
03-05-2015, 08:52 PM | #3 |
What's this pin upgrade? Just googled it and nothing. I could make a spacer. Not really looking to jump the crap out of it. |
03-05-2015, 09:00 PM | #4 |
| Re: Yeti bashing setup? Keeping inner hinge pins...? That is one discussion on this Inner Hinge Screws? This is the more in depth one, and there are several examples of it in oh so many build threads here Last edited by Rockwolf; 03-05-2015 at 09:05 PM. Reason: Added links |
Yeti bashing setup? - Similar Threads | ||||
Video - Yeti and Yeti XL - Snow Bashing! | BENDER | Videos! | 1 | 03-02-2015 12:11 PM |
Yeti Located - Axial Yeti bashing | eunique | Scale Videos! | 0 | 02-12-2015 08:42 AM |
Video - Yeti XL Bashing - 6S Lipo | BENDER | Videos! | 4 | 01-15-2015 02:11 PM |
Yeti Located - Axial Yeti bashing | eunique | Scale Videos! | 0 | 01-09-2015 02:10 AM |
Ultimate Yeti Crawling and Bashing! | téosrc | Axial Yeti | 0 | 11-17-2014 01:53 AM |
