03-17-2015, 07:33 PM | #1 |
Pebble Pounder Join Date: Feb 2007 Location: Ca 530
| Crawler02's axial yeti rtr with the normal upgrades
Finally had some time to grab some pictures of my yeti, I bought it from rpp hobby back in December and have been reading along here for some time now and have caught the addiction bad! Now all of my fun money goes into this The majority of the upgrades I've done were not due to breakage but rather preventing it by reading along here and upgrading as I could to make it a solid fun rig. Well here's what Ive done so far Vp trailing arms Vp lockouts Vp link mounts Vp slw front 225 rear 775 Vp dual sheer steering posts Vp diff cover Strc motor mount Strc bearing caps (rear) Strc cage stiffer Strc shock plates Strc shock tower Strc front pin mount Strc steering kit Strc caster blocks Hot racing knuckles Hot racing slipper plates Hot racing spool(rear) Axial hd gears stock ratio(rear) Bmrc turnbuckles Uc fab rear upper links D-lux u4 rear truss D-lux wraith mod housing (rear) Castle MMP Tekin pro4hd 3000kv Castle bec Savox sa1231sg(bad fit for yeti) RR 12t extra hard pinion 5mm Crawler innovations bumper insert Crawler innovations 6 bolt rims 1" wide M.I.P rear shaft Last edited by crawler02; 07-05-2015 at 05:12 PM. |
03-18-2015, 01:23 AM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: Michigan
| Re: Crawler02's axial yeti rtr with the normal upgrades
Hott damn whats not to love about a well broken in Yeti! I will sit down and commiserate with you on the YETI FEVER, because I'm pretty sure I'm about 2 weeks away from living in a box, and probably a few days less than that away from bachelorhood Those damn Yeti's |
03-18-2015, 01:26 AM | #3 |
oh yea i forgot, Great upgrade list on that beast mode yeti of yours and......... whats with the Subaru sticker |
03-18-2015, 10:35 PM | #4 |
Not a damn thing not to love here thank you sir! The subaru sticker snuck its way on there from my tamiya xv-01 kit but that's a completely different thread and Fever! |
03-20-2015, 10:26 AM | #5 |
| Re: Crawler02's axial yeti rtr with the normal upgrades |
03-20-2015, 11:25 AM | #6 |
Eddie to the rescue yet again |
04-09-2015, 04:11 PM | #7 |
Got just a couple more parts for the yeti I won't be installing just yet though. Im waiting for the D-lux front end setup to be ready with the new locker as that will be my next upgrade I do to this thing Axial hd bevel gears 13/38 Axial 64t steel spur I also changed the tires out to my r35 ripsaws on c.i 6 bolts |
04-15-2015, 09:06 PM | #8 |
Well got some free time so I installed the steel spur, and hd gears in the front end with some heavy diff fluid for now. Took it out and ran it hard all day on the rocks and toward the end of my run I had my rear mip shaft come apart and I almost lost the male shaft and all the parts! Luckily I found it all and got it back together with some red loctite an left it to cure overnight It was at this point I also noticed I had broken my rear truss somehow and after talking to the man himself I think it broke by dumb luck not a strength issue at all but I will be upgrading to the G10 version (most likely) of the truss once the D-lux knuckles/shafts/locker setup is ready to order again. |
04-15-2015, 11:23 PM | #9 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
NORMAL upgrades???? I think you should have bought the chassis and all your upgrades and saved the 300$ on the vehicle you have sitting as spare parts! LOL
04-16-2015, 08:20 AM | #10 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
Yeti looks great, what foams are you running in your ripsaws?
04-16-2015, 08:38 AM | #11 |
Newbie Join Date: Feb 2015 Location: Upstate
04-16-2015, 10:32 AM | #12 | |
| Re: Crawler02's axial yeti rtr with the normal upgrades Quote:
DTB1 I'm running the stock axial foams still in the ripsaws that came with my wraith kit. They are not even close to up to supporting the weight of this beast though I checked this morning and it's got a case of the flat tires lol. I'm hoping to upgrade to some voodoo u4's soon. Last edited by crawler02; 04-16-2015 at 10:41 AM. | |
04-16-2015, 10:40 AM | #13 |
That's what I am running on mine and I like them. But I really like the hill climbing performance that the ripsaws have provided on my wraiths. The voodoos are great tired but I feel they may need to be cut for loose hill climbs and I don't like cutting tires. |
04-16-2015, 10:46 AM | #14 |
Speaking of just buying a chassis though...I laugh at the fact that eventually my chassis will have worn to the point I buy a new one. Heres the belly of this beast after quite a few packs on the rocks, my vp trailing arms are finally starting to stop hanging me up on rocks everywhere and I have not bent a single hinge pin since going to rpm arms and the strc front pin mount!! |
04-16-2015, 10:50 AM | #15 |
| Re: Crawler02's axial yeti rtr with the normal upgrades That's good to know thanks for the insight I do a lot of wide open dirt hill climbs as well ever since adding the pro4 hd. That yeti of yours is a thing of beauty man makes mine look like a beater lol |
04-16-2015, 05:42 PM | #16 |
Yours makes mine look like I'm not tapping into its potential at all! I have been considering getting a truss like yours for the rear of my yeti. Did you have to alter your upper links any for it to work?
04-16-2015, 09:29 PM | #17 |
| Re: Crawler02's axial yeti rtr with the normal upgrades I absolutely love the truss and can't wait to get the stronger G10 version on here soon! I did have to also purchase the D-lux upper links that are a bit longer for the truss wich was my only slight downside as I had already purchased bmrc rear upper links.
04-21-2015, 04:30 PM | #18 |
Voodoo U4's climb extremely well bone stock |
04-21-2015, 06:35 PM | #19 |
| Re: Crawler02's axial yeti rtr with the normal upgrades This is the tire I have in mind when it's time I can't decide if I want to go for the gold or silver compound though. In other news I pulled the trigger and once axial has there yeti front locker off back order Mr D-lux will be sending me out the yeti front housing with the pinion bearing mod done, front locker/ofna shafts/knuckles/hubs and a G10 u4 rear truss that I cant wait to replace the broken cf truss with. |
04-29-2015, 05:20 PM | #20 |
