Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Hinge pins
Old 04-20-2015, 12:47 PM   #1
Default Hinge pins
I haven't even gotten my yeti kit ready to run as I'm still upgrading it and came across the hinge pins being weak as I'm not gonna bash it it's more of a trail rig but I know I'll hit something hard and I can see it binding so I was wondering what are the options for the pins
Mitchell72 is offline   Reply With Quote
Old 04-20-2015, 12:52 PM   #2
Default Re: Hinge pins
I will have the strc bumper mount
Old 04-20-2015, 02:30 PM   #3
I did this, using Lunsford T\E-Maxx pins
DLUX Swamp Squatch
And as you can see, it has seen some use since, with no issues.
DickyT is offline   Reply With Quote
Old 04-20-2015, 05:51 PM   #4
Thank you dickyt. I'll get some off those ordered up to make a solid yeti
Old 04-20-2015, 05:57 PM   #5
No problem, don't forget the 1/8" collars. They are needed to hold the pin in place.
Old 04-20-2015, 08:29 PM   #6
Who sells the collars
Old 04-20-2015, 08:48 PM   #7
I may be lucky but I have RPM arms on the yeti, I only runs 3s , proly 35 packs by now, and iv never bent a hinge pin. (Knock on wood )
BigBlokBoi is offline   Reply With Quote
Old 04-20-2015, 08:50 PM   #8
Dubro makes the collars. They are 1/8". I picked mine up in the plane section of my LHS.
Old 04-21-2015, 04:36 PM   #9
Sub'd for later use
Sh0rtBus is offline   Reply With Quote
Old 04-21-2015, 05:24 PM   #10
Hey dicky, i see you have your kingpin screw with the head on the out side of the knuckle. Did you use a thin nut or something?
ninja turtle is offline   Reply With Quote
Old 04-22-2015, 06:54 AM   #11
binaryterror's Avatar
I was the first using better pins, mine are Tungsten Carbide - won't ever bend, but sure if I hit something they could break. Then add in the collars and all set.
Really any good pin material will work; various tool steels, titanium, tungsten carbide, drill blanks. McMaster.com has all the options of materials you could want. And of course the 1/8" collars too.
binaryterror is offline   Reply With Quote
Old 04-22-2015, 07:16 AM   #12
I haven't had a single bent hinge pin since switching to the rpm a-arms.
Old 04-22-2015, 07:47 AM   #13
Neither did I, but for the relatively low money to change and the poor fit and design of the stock ones, having a racing background, no way I could live with the stock pieces. It is just a matter of time I make a wild jump and end up needing it anyway.
Old 04-22-2015, 08:16 AM   #14
I went through this extensively with an exo buggy. I think a lot of it comes down to factors outside the box some. First, the capture plates/bumper assembly. If they are plastic, they will give some and influence the a-arms which could result in a bend. You also have the way the capture plates mount to diff. You are then relying on the diff housing not to flex. Then mix in the gap in the stock, and even RPM a-arms, and now you potential for a lot of flex. The best solutions I had seen on the exo are gone (member vendors who went away), but for those bashing with the yeti, like my son, this is an area that desperately needs attention. My personal plan is to do some different things.
1. STRC bumper mount.
2. I am going to try a Mugen hinge pin I found yesterday.
3. RPM arm most likely drilled.
4. I am gong to make a sleeve for the rest of the a-arm.
I am not sure what I am going to do on the back of the Diff housing.
RickM is offline   Reply With Quote
Old 04-26-2015, 06:08 PM   #15
I'm using 1/8" ti rod bought of the internet. I drilled out the holes for em, bought 4 collars for $2.99 and all said and done $11.00 to make them pretty much bullet proof. Shipping killed me on the ti though. How can a envelope cost $7 with a chunk of ti in it that weight .007 oz?
Gixxer1237 is offline   Reply With Quote
Hinge pins - Similar Threads
Keeping inner hinge pins...? Sc91gt Axial Yeti 6 02-27-2015 12:55 PM
front hinge pins sally1800 Axial Yeti 25 10-27-2014 06:45 PM
Yeti hinge pins CKRC Hobbies CKRC Hobbies 0 10-16-2014 05:05 PM
Maxx hinge pins 666 Chit Chat 3 05-21-2006 08:40 AM
