Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Trailing arms
Old 11-10-2016, 08:34 AM   #1
Default Trailing arms
I'm getting ready to order my yeti kit and along with a bunch of upgrades. Was wondering the best trailing arms to get. Thanks.
PileDriver is offline   Reply With Quote
Old 11-10-2016, 08:35 AM   #2
Default Re: Trailing arms
Jec
Rjohn929 is offline   Reply With Quote
Old 11-10-2016, 12:36 PM   #3
SSD with hd rods
But the Kit ones with the plates are not bad. I would change them on breakeage.
i switched to the ssd only cause i needed a goodie for myself., but wasn't nessesary.
sent by magic_yeti
magic_yeti is offline   Reply With Quote
Old 11-10-2016, 12:59 PM   #4
SSD
Our trailing arms are packed with HD rod ends only now.
SSD is offline   Reply With Quote
Old 11-10-2016, 09:25 PM   #5
I was leaning toward ssd but also the vanquish arms not sure how well the ends hold up on the vanquish. Are the ssd 3mm or 4mm rod ends?
Old 11-10-2016, 09:34 PM   #6
3mm. That is why I went with JEC/Supershafty. Not necessarily because they would break but because I have a ton of traxxas ends and I can get the traxxas ends anywhere if I need them. The SSD not so much.
Old 11-10-2016, 09:52 PM   #7
That's the problem I'm having. I'm trying to have all my rigs use the same rod ends.
Old 09-01-2019, 11:37 PM   #8
Is possible to install revo ends int ssd trailing arms?
Taper is offline   Reply With Quote
Old 09-16-2019, 03:07 PM   #9
Moderator
I have the JEC Stainless on my Bomber. They're indestructible. They're also very, very heavy. When I built my Yeti, the Aluminum JECs weren't available, so I ended up going with a set of MFR trailing arms. They're ridiculously light, and to be honest, I'm a bit nervous that they're going to snap in half, but so far, they've taken everything I've dished out.
Jim85IROC is offline   Reply With Quote
Old 09-18-2019, 10:50 AM   #10
JEC has some industrial nylon (Delrin) versions now available:
https://jecracing.com/collections/j-...er-ta-s-delrin
I have the complete Bomber stainless link and trailing arm setup from him, very heavy - but it does tend to keep my rig planted!
My second Bomber will use the set of stainless links from an eBay seller called "american_machine_works_ohio" that I bought last year, but it looks like they may have stopped producing them. Very nice as well, but I haven't got around to getting the trailing arms yet - will either get SuperShafty aluminum BombProof arms (currently sold out) or the JEC Delrin this time.
https://supershafty.com/collections/...-trailing-arms
The SuperShafty arms are slightly re-profiled from the original JEC design. I think they look a little nicer now... but slippery Delrin may win the day!
durok is online now   Reply With Quote
Trailing arms - Similar Threads
trailing arms PileDriver Vaterra Twin Hammers 2 05-25-2016 05:02 PM
1/18 Trailing arms?? SwampDawg Micro Scale Rigs 0 05-04-2016 07:53 AM
trailing arms? haynesn12 Axial Wraith 5 01-03-2014 11:26 AM
