Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Limited shock travel
Old 11-22-2015, 04:06 PM   #1
Default Limited shock travel
Just put together my kit icon shocks. All seems smooth until I fill them and put the cap on. Once the cap is on, won't even travel half the shock length. It is as if the piston isnt allowing fluid, but I don't know how it could be blocked.
Rears only. Front seems fine.
Caswell is offline   Reply With Quote
Old 11-22-2015, 04:39 PM   #2
Default Re: Limited shock travel
When you fill them with fluid, make sure that when you are ready to put the cap on that you only thread it on about half way and then compress the piston to allow the excess fluid to come out.
Sent from my LG-D850 using Tapatalk
RC for life is offline   Reply With Quote
Old 11-22-2015, 05:03 PM   #3
Shock Building Tips
Cultus is offline   Reply With Quote
Old 11-22-2015, 06:55 PM   #4
When building shocks with oil in them compress them all the way then tighten shock cap.
tapped-out is offline   Reply With Quote
Old 11-22-2015, 07:16 PM   #5
You have too much oil in your shocks, take some out and you should be good
Sent from my XT1042 using Tapatalk
mattehmer01 is offline   Reply With Quote
Old 11-22-2015, 07:21 PM   #6
Originally Posted by Cultus View Post
Why isn't this in the instructions? They work WAY better. Even redid the fronts.
Sent from my SM-G900W8 using Tapatalk
Limited shock travel - Similar Threads
limited travel after adding shock arms..HELP PLEASE! -BIGMAXX- Team Losi Comp Crawler 7 11-23-2011 03:22 AM
Limited shock travel clowkoy HPI Wheely King 11 04-16-2008 08:12 PM
Shock Travel? dlc Newbie General 2 11-13-2007 12:37 AM
Shock travel Reflection General Crawlers 6 11-04-2004 05:16 PM
Need more shock travel Reflection General Crawlers 8 06-28-2004 03:50 PM
