11-23-2015, 04:02 PM | #1 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
| Improve pinion angle by swapping 4 link mounts
Hey guys I thought I would share this. After I got my new link mounts installed I was looking for ways on how to improve the pinion to drive shaft angle. Before the pinion was pointing slightly downwards. So I figured out I could swap the 4 link mounts, keep the lower links on the outside, but move the top links inward. This rocks the rear axle back slighly. Now at mid suspension travel, my pinion is pointing dead center at the transfer case output shaft and is slightly up at full droop. Are there any negative effects of having the upper links mounted inside of the lower links? |
11-23-2015, 04:16 PM | #2 |
Rock Stacker Join Date: Aug 2015 Location: jackson
| Re: Improve pinion angle by swapping 4 link mounts
the only bad thing is the pinion angle will change as the suspension moves up and down .
11-23-2015, 04:19 PM | #3 |
Less triangulation equals more axle swing. If you care.
Improve pinion angle by swapping 4 link mounts - Similar Threads | ||||
Confused about 3 vs 4 link and pinion angle | b4tn | Axial SCX-10 | 10 | 02-01-2015 08:53 PM |
TF2 Rear 4 link pinion angle?!? | sickcivic95 | RC4WD Trail Finder 2 | 17 | 01-24-2014 09:56 PM |
How to improve turning angle on SCX? | josruu | Axial SCX-10 | 24 | 04-27-2011 01:54 AM |
Pinion angle/upper link length | Planespotter | Axial SCX-10 | 7 | 07-27-2010 07:17 PM |
Upper Link Spacing & Diff Pinion Angle | mtec | Axial AX-10 Scorpion | 5 | 01-22-2009 05:34 PM |
