Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Yeti shock oil weights?
Old 09-06-2014, 06:06 PM   #1
Default Yeti shock oil weights?
I know its here somewhere, I read it at some point.....but do you think I can find it now....NO!!
could someone in the know please help?
Thanks!
skybolt is offline   Reply With Quote
Old 09-06-2014, 06:25 PM   #2
Default Re: Yeti shock oil weights?
30wt in front and 10 wt in the rear.
SteveC6R is offline   Reply With Quote
Old 09-06-2014, 06:28 PM   #3
Awesome! Thanks!
Sent from my iPud using Tapatalk
Old 09-07-2014, 01:40 PM   #4
I run a spare tire and did green springs and 30wt oil and it made a world of difference. It's dialed in awesome
AWraith build is offline   Reply With Quote
Old 09-07-2014, 02:07 PM   #5
Come and take them!®
Hunter711's Avatar
Orange springs rear w/ 20wt Associated
Stock Grey springs front w/30wt Associated
Stock pistons
Feels good to me.
But that's me.
PS. Battery weight has everything to do with it.
Hunter711 is offline   Reply With Quote
Old 09-08-2014, 06:56 AM   #6
binaryterror's Avatar
Which Orange springs? The stock ones on the Yeti are supposed to be their Orange spring per the manual (gray, but the ends painted orange).
binaryterror is offline   Reply With Quote
Old 09-08-2014, 09:00 AM   #7
Hunter711's Avatar
All springs are grey. Color on ends is the only distinguishable marking to verify ratings.
Edit: My springs came grey, no color marking. I purchased orange springs after the fact.
Old 09-08-2014, 10:13 AM   #8
I run a 325g 4s pack sorry I forgot to mention that.
Old 09-08-2014, 11:14 AM   #9
Interesting, I'll have to check mine now. I know the manual puts the orange springs on stock, but if they aren't marked who knows what they are.
Old 11-16-2014, 08:06 AM   #10
I have 350 oil in rear with stock springs and 600 in front with stock springs. Front is still way to bouncy. Rear is just about right. May try some different pistons in the front shocks to get more dampening.
Also running a 2200 3s lipo.
J_Fitz is offline   Reply With Quote
Old 01-01-2015, 05:43 AM   #11
How much oil is in shock?
Are they 100%, 90% or 75% full or something else?
dbuus is offline   Reply With Quote
Old 01-01-2015, 07:23 AM   #12
Hunter711's Avatar
Read these for some understanding:
1)Learn from the Pro's: TLR's Adam Drake on building perfect shocks - RC Car Action
2)http://www.rccaraction.com/blog/2013...ks-like-a-pro/
Old 03-15-2016, 11:20 PM   #13
Hello Yeti builders. First sorry my bad english, im from Finland.
I have little shock problem/question.
Have you put any rebound on Yeti's stock shocks? I made my shocks just like the manual say's (shock arms 100% out and put oils in etc..) and rear shocks feels very very hard, fronts feels smoother.
WTK85 is offline   Reply With Quote
Old 03-16-2016, 05:13 PM   #14
If your shocks are too hard you should take them off, unscrew the shock cap, compress the shock until the piston is Almost to the top of the fluid--and while holding it compressed, screw the cap back on. Doing so will give very little to no rebound.
Just remember when a shock compresses the shaft adds it's volume to the fluid.
Good luck hope this helps.
battery is offline   Reply With Quote
Old 03-16-2016, 06:14 PM   #15
running 3s and 2-speed trans- i love 50 front 30 rear, and build the shocks with minimal rebound....
chas
colorado chaos is offline   Reply With Quote
Yeti shock oil weights? - Similar Threads
motor oil as a shock oil? Mr.JayDeeM General Crawlers 10 09-02-2012 10:59 PM
best shock oil and gear oil j4k3 Axial SCX-10 2 07-26-2010 12:48 PM
shock oil weights drawls88 Team Losi Comp Crawler 5 11-08-2009 06:22 PM
oil and spring weights hpiguy Tamiya TLT Crawlers 11 12-08-2005 07:58 AM
