04-27-2016, 11:56 AM | #1 |
Rock Stacker Join Date: Feb 2016 Location: Ft Myers
| The Yeti has landed. Battery question
My RTR Yeti arrived yesterday from Tower. What a difference from the SCX10 Deadbolt, it's a lot faster than I'm used to. I have a few Zippy hardcase 5000mah 3s batteries that I've been using on the deadbolt. They wouldn't fit in the Yeti, they were to tall to fit under the battery brace so I removed the brace. It fits perfect without the brace. Besides holding the battery down, is this brace giving the frame any support? I still have to make a short servo extension so I can connect the CC bec without cutting the wire on the throttle lead.
04-27-2016, 12:20 PM | #2 | |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: The Yeti has landed. Battery question
Did you try adjusting the brace height? How tall is your battery? Quote:
04-27-2016, 12:30 PM | #3 |
Newbie Join Date: Apr 2016 Location: Des Moines
Should just be able to remove a few screws and adjust the bracket height to fit your battery and tighten the screws back down at the wanted height. I had to raise mine up a little when I changed from 2s over to 3s. You will want the battery to be braced down so it doesn't just fly around in there when you flip it. Last edited by Hedsic; 04-27-2016 at 12:36 PM. |
04-27-2016, 12:41 PM | #4 |
Those must be some big ass 3s packs. Here is a 6500mah 4S in my Yeti with the top brace removed. |
04-27-2016, 06:27 PM | #5 |
| Re: The Yeti has landed. Battery question There almost that big, the hard case makes them a little bigger. I already adjusted the bracket as high as it would and it just a little to big. I'm going to use a velcro strap. It's a nice car, I'm impressed.
04-27-2016, 08:25 PM | #6 |
Just wanted to make sure you knew it's adjustable. It is a fun rig for sure!!
05-01-2016, 07:03 AM | #7 |
Rock Stacker Join Date: May 2015 Location: central PA
I had to take the same route when using 3S hard cased packs...off with the battery clamp. My 3S packs fit snug in the tray, and they're only 4000mah packs. It's a pain in the butt when changing between motors and battery configurations. I've been putting off making some use of Velcro straps to make the job easier...especially if you got all kinds of battery packs like I do. Two straps should be enough.
05-01-2016, 03:56 PM | #8 |
Pebble Pounder Join Date: Apr 2010 Location: Charlotte
Im using a 5200 mah lectron pro from common sense. It fits fantastic and has room to spare both length and height. It's a 60c pack I believe and has plenty of punch. The truck flips over backwards on stock gearing with traction even after running the pack for 30 minutes Sent from my iPhone using Tapatalk |
05-02-2016, 07:04 AM | #9 | |
| Re: The Yeti has landed. Battery question Quote:
05-02-2016, 08:42 AM | #10 |
| Re: The Yeti has landed. Battery question I bought the lectron because I couldnt find anything else in stock actually that was close to the same size. Ive been very happy so far with it |
05-02-2016, 06:37 PM | #11 | |
ZIPPY 5000mAh 3S1P 30C Hardcase pack (US Warehouse) | |
05-03-2016, 05:54 AM | #12 | |
05-07-2016, 08:03 AM | #13 | |
Rock Stacker Join Date: Jan 2016 Location: South Joisey
Just take a tiny screwdriver (or razor blade edge) carefully pop up the plastic tab on the connector and pull out the "+ wire" pin (the Red one in the middle). Then use a piece of heatshrink or electrical tape to wrap the pin. I do that on all my rc's with an external bec so that if I decide to change something it's as simple as popping the pin right back in. Hope this helps. Last edited by battery; 05-07-2016 at 08:06 AM. | |
05-09-2016, 06:22 AM | #14 | |
The Yeti has landed. Battery question - Similar Threads | ||||
Yeti XL Battery Question | stonecold | Axial Yeti XL | 2 | 02-11-2015 05:16 PM |
Plane landed on top of Semi | JasonInAugusta | Chit Chat | 1 | 12-10-2004 03:42 PM |
