05-06-2016, 11:41 PM | #1 |
Newbie Join Date: Mar 2016 Location: Miami
| Yeti randomly turns off and back on
I am having a very odd issue with my yeti. Stock esc/motor and I am currently using a fly sky receiver/radio combo. Fresh battery, I drive the truck and it will be fine and then randomly stop responding. Truck then jitters a bit, and doesn't respond to throttle/steering and sort of like reboots itself. Esc makes the noise that it does when it powers on and then it works again. Drive it for a minute and this repeats itself. I have also tried putting the factory receiver back in but when I do the truck will get no throttle response. Steering works normal but no throttle. Receiver is connected properly. I also have a total of 3 fans connected to the fly sky when it has this issue I'm not sure if that can cause it. One fan on the esc and two fans wired together into one connection for the motor.
05-06-2016, 11:45 PM | #2 |
Pebble Pounder Join Date: Jul 2009 Location: Douglas
It's probably the on off switch. Solder the two wires going to the switch together. Those switches usually go bad. Sent from my iPhone using Tapatalk Last edited by lv-eg; 05-06-2016 at 11:57 PM. |
05-08-2016, 09:21 PM | #3 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
| Re: Yeti randomly turns off and back on
The esc may be thermalling. When you experience this, are you crawling/ driving slowly? The sensorless motor likes to keep spinning. Start dropping speed, trying to crawl and temps will spike quickly. The stock gearing doesnt help either. Solutions: Drop a few pinion teeth, get a sensored system or just keep your momentum up. |
05-08-2016, 11:35 PM | #4 | |
Rock Stacker Join Date: May 2015 Location: Saint Louis, MO
| Re: Yeti randomly turns off and back on Quote:
I also had the thermal issue when I first got my Yeti. The motor would stop working but the steering servo still worked just fine. BTW the factory RX is Flysky compatible. I use the factory RX with a FS-GT3C TX. | |
05-09-2016, 03:52 PM | #5 |
So I just wired the on off switch directly and it still does it. I would imagine it's not thermaling because I have a fan on the esc and 2 on the motor. I do have a temp gun though so at what temp does it thermal so i can check?
05-09-2016, 04:22 PM | #6 |
Newbie Join Date: Apr 2016 Location: Manchester
Does it do it in the first say 5 mins of running when the esc is cold? I'm not sure exactly what temp it will shut down on thermal but it will feel pretty hot |
05-09-2016, 05:22 PM | #7 |
Quarry Creeper Join Date: Nov 2014 Location: WA
Temp gun is always your friend. If the ESC/motor temperature is higher than 180F may be the reason. Fans help but didn't make miracles. |
05-09-2016, 07:05 PM | #8 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Long shot but check you solder joints on the esc side of the battery plug. Or if you changed the plug make sure it is making a good connection.
05-09-2016, 07:06 PM | #9 |
Pebble Pounder Join Date: Apr 2010 Location: Charlotte
Get a temp gun and run it with the body off. As soon as it cuts off check the temp on the esc and the motor. Also, have you updated the firmware on the esc with a castle link. Mine would get very very very hot while driving around, motor and esc, but I never had it fully thermal. I bought a castle fan for the esc and it did cool it a tad but let's face it, it isn't doing much. I did update my firmware and it does feel cooler to the touch. It's only very very hot now. Lol. I still have to pick up a temp gun, I'm gonna order one Thursday (payday) Sent from my iPhone using Tapatalk |
Yeti randomly turns off and back on - Similar Threads | ||||
SCX10 Throttle Randomly Reversed... | binns.mark | Electronics | 1 | 09-14-2014 12:48 PM |
gt3c randomly turning off | m1009cucv | Electronics | 5 | 09-24-2012 06:48 AM |
My Honcho turns into a rubicon unlimited, no going back now | northernerbill | Axial SCX-10 | 91 | 04-20-2012 04:52 PM |
Losi night crawler turns left when control turns rt | Jophuss36 | Electronics | 3 | 07-09-2011 11:29 PM |
quark/OG revolver overheating? randomly shutting down.. | dieselfuel | Electronics | 8 | 08-21-2007 09:29 PM |
