08-25-2016, 06:40 AM | #1 |
Newbie Join Date: May 2016 Location: Australia
| Shock Oils
What weight oils do you run for stock yetis? Front and rear |
08-25-2016, 07:50 AM | #2 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: Shock Oils
Rtr comes with 30/10 F/R. I ran 30/20 on my stocks before the rig started getting heavier with aluminum upgrades. I run prolines all the way around now with 40/30 and stiffer springs.
08-27-2016, 07:51 PM | #3 |
Rock Stacker Join Date: May 2015 Location: central PA
| Re: Shock Oils
45wt/30wt (front/rear Associated oil) for everyday bashing. The 10wt that comes in the kit is pretty much useless to me. If I am running trails it's okay, not really. Any kind of speed and any kind of bump/jump and the rear will bottom out...serious donkey kickin' going on.
09-02-2016, 08:16 AM | #4 | |
Rock Stacker Join Date: Dec 2015 Location: Deep South
| Re: Shock Oils Quote:
Thanks in advance! | |
09-03-2016, 06:24 PM | #5 |
Rock Stacker Join Date: Jul 2015 Location: California
| Re: Shock Oils
I am running yellow (stiffer axial springs) on the front. Oil is 40 front 20 rear for me and it works great! It's a heavy vehicle, and the front was just sitting too low in the travel all the time with the stock springs. Rear is fine as long as you add thicker oil. |
09-04-2016, 04:36 AM | #6 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Shock Oils
My current setup: front: Oil: 700cst (think. approx 60wt) Spring: blue 70mm axial spring. Tried it first as it was recommended in many build threads here and it was perfect. rear: Oil: 500 cst (think app. 40wt) Springs: 54mm white and red ones out of the hot racing front spring set, using the spring connectors i found on a part tree of my kit. Happy so far with this setup till now. Maybe i have to go up with the Oil cause my little monster gets heavy with all the upgrades. |
Shock Oils - Similar Threads | ||||
New Kit, greases, shock oils, etc? | Beej | Axial Wraith | 2 | 11-28-2011 08:31 PM |
Shock Oils! | thzero | Axial AX-10 Scorpion | 5 | 02-10-2011 09:08 AM |
Mixing shock oils? | diyfer | General Crawlers | 6 | 04-28-2010 08:24 PM |
tuning with different shock oils | speedemall | General Crawlers | 6 | 09-02-2008 08:22 PM |
shock oils | al3x_34 | General Crawlers | 0 | 07-06-2007 01:18 PM |
